Operation SOA 75 (2 Viewers)
haha nah that's my mates shortie
We just finished building her the other day.
Cheers guys,
I made my dump pipe today, it was a hell of alot easier than i thought it was going to be, all i needed was a gimpy and a piece of 1" solid rod oh and a bit of time.
I squashed the end of the 3" tube piece down so it was the basic profile of the flange, then used the hammer and rod to go around and peen it out, tacking as i went. I then got a 3" mandrel bend and welded that on for the drop.
Came up perfect, not bad for my 1st attempt.
Well i pulled the car in today, stripped the front housing, ground and cut the knuckles ready for another 'cut and turn'. I went for 4.5deg this time as my last C&T came out as 8deg for some reason...#-o and u know what?
NO MORE DEATH WOBBLES!!
Ive pulled it back down again to brace the knuckles
Pix lata
Castor corrected and braced, no bending these puppies
Drives awesome now!
New Vid @ ~10psi and fuel increased.
As always videos like this just don't do things justice...
When all said and done, i doubt i need much more power than this...
1HZ Turbo @ ~10Psi
Drives awesome now!
1HZ Turbo @ ~10Psi
Excellent build. I have been looking at the GT2876 -70330-1 Garrett and was wondering which actuator you used. Where did you pull the coolant from? Did you use an oil restrictor? Thanks great build!:beer::beer:
Cheers mate!
My series GT2876R has an oil restrictor inbuilt, dont know what kind of actuator i got but its a 12.5psi job, i had to make my own mounting plate and linkage for it though.
Ill try and get a pic of it for ya sometime
Cheers fellas:beer:
Wow! That sounds fabulous! Now I really want to turbo one of my rigs. This has been a very entertaining build thread from the very beginning. Keep up the good work!
Best regards,
Shaun
Cheers guys!
Ill have to take it out for a bash some time and get some good footage
Work has been absolutely full on so i haven't had much time to do anything, but i have installed my temp and Pyro gauges.. Enjoy
that is a perfect use for the otherwise useless spot. i always wondered why an altimiter was installed in the JDM units...
shes a beautiful build M8
thanx mate, its a little hard to see the whole gauge as its on a bit of an angle but its good for now, im going to make a face plate with angled gauge holes later on.
You can pickup these angle rings that fit behind the gauge and angle it toward the driver a bit, they work great.
Good Built
Cheers :cheers:
Michael
cheers Michael ill have a look for these rings
Ok well a bit of an update, i have finished the water cooling on the turbo and a temporary intake away from the turbo.
I thought id see what would happen if i took the waste gate actuator off the turbo... and this is what i found :D
YouTube - 1HZ Turbo @ over 20psi
Dodgy video i know... done with my phone, holding it while driving... only 1st gear lol....
