Well, here goes.
My roller bearings are also completely seized (at least the one I pulled apart and I have no reason to think the other one is any better). Yours look a LOT better than mine. And feeling how the inner sleeve spins with a seized bearing, I'm pretty sure they've been like that for at least the 11 years that I've owned it. I never knew there was a bearing in there - probably because it didn't feel like there was one.
Mine are M47C, which apparently actually means something. My bearings are smaller than yours. There isn't enough flat edge exposed to even print any kind of name or number. The rollers appear smaller in diameter as well, which probably makes sense.
The good news is that there is no real stress on that bearing at all. It's just there as a support for the birf stub shaft when freewheeling. When the hub is locked in, that sleeve/bearing don't spin at all in relation to one another.
So if a bearing store can't help you, the good news is that it'll probably work just fine for a long time.
