Old Landy: An HJ45 Story/Build Thread
90311-33085, Type T oil seal for front drive shaft x2
90311-47001, oil seal for rear axle shaft x2
Differential oil seal in original factory wrapper.
Transmission oil seal for rear bearing retainer x2
Piston ring compression tool
Miscellaneous brand new gaskets
81572-26040, rear combination lamp gasket for left hand side
63313-90303, Roof drop molding packing gasket
63161-60011, Roof weather strip
58263-90300, Shifte selector lever boot #1
Rear main seals x2
Miscellaneous seals. Did not get part number. Will edit when we get back to the Elf Barn. Still can’t get over the neat origami packaging.
Assortment of fuses and bulbs. Love the way Andres packed them. Self contained plastic boxes. Survived three continents.
Alternator, clutch plate, clutch disc.
Assortment of engine gaskets for H engine.
Also note about 30 knuckle shims in lower right corner.
New clutch release bearing.
Not sure what this is. Looks like master/ Soave cylinder dust seals.
Door regulator escutcheon (black)
Another transmission seal for rear bearing retainer.
Box of bandaids. Has brail lettering too!
Patches, 2 new tubes, valve stem patches for split rims. Extra ubolts. Bag full of spring and shackle bushings. Spare frame spring perch eyelet
Unicorn piece for sure, engine bay light
