- Thread starter
- #261
hey, epoxy primer again???
Had a lot of dedicated time over the weekend in the garage. 12 hours yesterday, and 8 today.
Started with taping down the lines for the seam sealer. I used SEM 2 part sealer, and was happy, but learned that the working time is not enough for one person. you need to have a buddy there to pull the tape after you lay the sealer down, and set it into the grove with your finger. I laid down about 10 feet of lines, went back pulled the tape quickly, dipped my finger in laquer and went across the lines to lay them down flat, and when I picked up the gun to go to the next section, the sealer had hardened in the mixing tube. Lesson learned. Overall, I am happy with the sealer, but not perfect. Oh well, I will know better for next time.
So, I hung all the pieces in the makeshift paint booth, cleaned everything with Southern's water based cleaner (mostly rubbing alcohol by my nose test) and let it set for an hour.
