Builds OKADVENTURES GX470 Build (31 Viewers)
Shipping took like 7-10 days, not bad at all. The shipping price is a little steep like you said especially if you’re only getting one thing.
Can you provide some measurements in terms of how much room is there above the attic shelf? Dimensions of the shelf like width, length, height of lip?
Thanks. And I’m looking forward to your video on how you plan to use it.
I already have ideas that an attic shelf is great to store easy to access items like a first aid kit, tire repair kit, compact portable air inflator, flashlight, etc.
Center height to top of lip: 6”
Center height inside lip, 6.5”
Rear Lip height: .5”
Front lip: 2.75”
Depth: 18”
Width: 41.5”
ceiling to top of lip at either edge: 1.75”
Ceiling to shelf height at dead center of shelf: 6.75”
Here is a pic of what I have up there now, med kit, paper towels, blanket. Still tons of room left. Hopefully this was helpful!
That was super helpful. I saw some small husky/rigid cases at Home Depot that are like 4” to 4.5” high that can fit up there easily.
I have one of those Rigid cases you're talking about (made it into a gun case). I'll throw it up on the shelf and see how it fits.
Here is the one I have: RIDGID 22 in. Pro Organizer,
I can confirm this isn’t even close to fitting because of the angle you have to put stuff up on the shelf. You could maybe fit a thinner hard case.
I think the shelf is more suited to soft goods.
I did see someone make some brackets to lower the shelf some, but then it will interfere with your rear view mirror visibility more.
Thanks for the info. The case I saw at Home Depot was less than 4” thick, but I suppose the approach angle will determine if it fits or not
This is good info nonetheless.
I installed the Desert Does It front seat jackers and multi mount panel in my GX470 and I was amazed with how much it improved the comfort of this truck. I thought these may primarily benefit taller people (which I am sure they do), but even being average height, I noticed a drastic improvement with how comfortable I feel in the driver’s seat now. The multi mount panel also adds a very convenient place to store various items like a knife, radio, emergency escape tool, fire extinguisher, medical kit, or whatever else your imagination can dream up.
Definitely give Desert Does It a look if you would like to improve the comfort of your adventure rig. They make seat jackers for a number of different vehicles.
Discount code “OKADVENTURES” will save you 10% through 05/31/2022.
Front Multi Mount Panel (Tacoma, 4Runner, FJ, and Lexus GX)
Front Seat Jackers (2003-2022 4Runners, GX, and FJ)
DDI Patch and Sticker Kit
MMP Magnets
MMP Magnets
Just ordered the seat jacker and multi-mount panel…
used your code, worked great!
Thanks for the tip.
Thanks for the tip.
And just installed them...couldn’t be easier with the excellent instructions.
They work exactly as advertised…really changes the seat angle (for the better). Whereas before, I had it cranked basically to the top just to get some leg support, with these jackers I now have the height-adjuster closer to the minimum setting.
It actually is more comfortable now, and gives me a lot more adjustability range.
I also got their multi-mount panel. Needed a quick-grab spot to mount my Element fire extinguisher and this works perfectly. There is room left over for something else…radio, knife, pew-pew, etc. AND, there’s room created behind it for other quick-grab items.
Its not the cheapest but it certainly works, and the quality of the items, fantastic packaging, fast and free shipping, and great communication adds up to a pleasurable buying experience and a satisfied customer.
Thanks again for the discount code!
They work exactly as advertised…really changes the seat angle (for the better). Whereas before, I had it cranked basically to the top just to get some leg support, with these hackers I now have the height-adjuster closer to the minimum setting.
I am glad you like them as much as I do! Cheers
Not exactly GX related, but it is overlanding related! I recently got in the Camp Chef Rainier 2X from Overlanded.com to test out, and review for the channel. It is a really cool camp stove that gives you a stove and a griddle all in one. Overlanded gave me a discount code to share with all my viewers so watch the video to get that if you want to pick this stove up for yourself.
Overlanded.com
Got any discount codes for Bison? That shipping $ is ridiculous.....
Looks like you went with the Medium size (11" tall). Any reason you didn't go for the taller one (14")?
Sorry I don’t have a discount code for them.
When I got my fold down table there was only one size available. I think mine is the smaller of the two that is currently available.
I installed the Roadshock Ditch Lights (Flood version) from Harbor Freight recently and was really surprised with how good the light output was from these budget friendly pods. I used the JW Offroad ditch light brackets to mount them and the brackets are rock solid. If you are looking to step up from the cheap amazon pod light options but not quite ready to drop $250 on a set of pods, give these a look!
3 In. LED Flood with Side Light - Pair (harborfreight.com)
GX470 Ditch Light Brackets | Lexus GX470 | GXOR | JW Offroad – jwoffroad
Check out this video I did of the OKMO G1000 Power Station. They are having a sale right now if you have been needing to upgrade the power supply for your overlanding setup. So far, I have been really impressed with this unit but I will be continuing to test it out and share my experience with you all.
G1000 Model
SG1000 Model (ON SALE)
G2000 Model
SG2000 Model (ON SALE)
G1000 Model
G2000 Model
On these power stations, one problem area is the number of times you can recharge the battery.
The new technology called LiFEPO4 which stands for lithium iron phosphate allows the battery to be fully charged 2500 times.
If it’s not LiFePO4, then the number of full charges drops to like a 1000.
I know bluetti power stations use LiFePO4 so that’s one I’ll be looking at.
Not sure how many time you can recharge the okmo brand power stations. I think most jackery’s are also in the 1000 range.
Anyways, I thought I share this piece of info on power stations.
Thank you for sharing that info!!
This isn’t directly GX/Overland related but it will live in my GX so I feel it is relevant!
I recently partnered with Refuge Medical to make a video going over their Adventure Kit 2.0. This is an extremely thorough emergency medical kit to keep in your vehicle, whether you are just commuting around town or on an epic adventure. Refuge Medical gave me a discount code to pass along to you all so check out the video to get that and save a few bucks on some life-saving equipment.
