NeverGiveUpYota
Dare me.
Anyone ever have an oil pump pass the diagnosic test in the 2F Engine book section 4--6, fig 4-13?
"Immerse pump suction end into clean engine oil and turn the pump shaft clockwise with a screwdriver until oil comes out the discharge hole."
I have my stock pump and a pump someone gave me cheap. Neither discharge oil from the hole. I'm a tad perplexed. Want to be sure I am actually doing it correct per the book, seems strange neither pass.
I'll add that neither gear pass the feeler gauge tests on my stock pump and visually I can see the used pump I have is just as snug gear edge to housing as mine. Quite sure, 99%, I am using the correct feelers but the gaps are too tight not too loose. Both are Aisin/teq marked. Anyone know if those are different gauges from what you'd use for adjusting valves? @Onur, @Cruiserdrew??
