Oil Pressure Gauge FIX
Knoxville, TN
Well, like many on here, I’ve experienced the dead oil pressure gauge in the dash of my 80. While most would probably say, “replace the gauge and move on”, I am really cheap, and felt like taking the dash apart… Cliff notes: I ended up bending the gauge internals to get it to read again. Description on testing process and how to perform the crude adjustment follows:
To give you a little background. My gauge worked when I purchased my 80, and after I replaced the thermostat for some reason my oil pressure gauge didn’t register anything anymore, but it would occasionally bounce around. After some digging, I found I must’ve broken one of the wires to the sending unit while replacing the thermostat. By being lazy and not addressing it quickly, I believe the wire grounded out long enough to burn up the gauge, sort of. So, it eventually stopped bouncing and stayed dead all the time. Once I put a new terminal end on the wire and hooked it back up, it was too late. The gauge remained dead. So, I decided to figure out what I broke.
I started by performing the test in the FSM in order to determine if it was the gauge or sending unit. I started by testing the sender cause I didn’t have the 3.4W bulb required for the gauge test.
5w2ufBkxEJgJ9tLCfj0XmNDqlx3ZFZW8KKXn8Eo3DGcc1zTMQm_z1UiaRqMkBZD10iZuYBsrzb4OSlXPRuoQ03btUAHeMxG2aGZXFzd-2A6CqWmWRy8XZmq_oSy9hgOg-4-F_O9tbVRQ8iBryWNAS0vZc6GyxUcTI-Czt1nj2nXhPEiQPdTnVDplKoUYnEJAENVVgY9a6DB3TpdeF-h7HOzJGzA89zuOgg9kGEz5EGl4K5tBIA9Xfm3sN80hdaJJziEQiPdF4aDD9U8i5_mslkNK9K7jAJkE5aoLI2lPPdNJYjfvuruQ8iPE6qdmTAqOBEK-ByeEKnxSvwnWr9AGLpF054TXQWSLzOX2aejf3XIVrePCy6gVbSCRlnQfPVTPC_E5PrzspbbBxI-n_QtxUyygVJRhwJpD1OZzARdPoFHNuw8Q54fV8ecDKfgg-K5Wwg48GLlUONlYj4-h39j7LqoCAs_B47XZTpDjkYH_8ivpGyZzCE0qJR1POXvFpjWSSmCFIkyEzgKhiki3igntUZPysTW4r0DY-ZeDim9Mg6RbLL5CWBlOpLo_OPq-fqjkEHhjmC4VIKGfXVY5nurv252TIVzJiNdmlqRpRPU=w608-h164-no
The sending unit passed the test (as expected); so, I had to find a 3.4w bulb at the auto parts store. I also bought a pigtail light socket for marker light that would fit the bulb while I was there. I then followed the FSM for testing the gauge.
2p_eRETRwghijn3eaS1bk5KG_EKTmYgTfiNuzVx-TmfL8q9KTp37vVNQ1VU7QThqXOrpCt_shqZPkLbFIaINQnmVD0tUmd4Ug-Zn1csPvvSQI7IUN-PRi3FRNAy3VlQ_hQNFP2i-wiSpqOq5I1OYKNo3T7SOj4g-vdRKrofimVNF2qz4sv0SWIa2yBIrighVnlUJh5NOvpd0sSyo5c5Phu6SS0V_uJbggpSgTLMSXanf_uZmJbzawlR-R3zv9rs42_XYV6YJmOg6rqbRwuWG8Sq0l9Pf5YFbcOZTT2dMiFGB5sCN-C0KB-yqhG_qcsb_VEyJISGz0BgbpNH5K87AekRvgLMkSaOrPkBLZDK7ikDs-TE_9OBvcZsh-eUBKtrg9OTMvY-ZRNExAybfeDZAOOKbsbr8TY-akHDmTD9O-3KnXfCyPhCnMD4_c5g4JWeq44tEsA3jmwI5GpT0lIvvFFfqnzVe-Yh04akcw4H6WDqDTmOVkaCJZT-BYfqZYwT2G4GrUvxJVg1HY35Qdir8kBvglAM3AHX3aTuds6UoHY9n7PlCXcgqSMm1C-m9y1uX7xpD4NNkBiR7AZz0C_FcbTs4YOBwMqMwhqvmEkA=w616-h179-no
uaC9HUXUBHZ7usWecFPlR9LM8CSP2LkQRVIKayfV_l6IOHpBMjePd6F-ycjHJa8A-RgOpEoVgckeSF8EtrqyPNGbhUcfJHSQSrB8RssP6mX2OJe0cpxpaYPRD9rWUd_48sMzOaAZmQyqXkNOC6xWwawDjlmomoQC-L1-t903azD-Iyc0_AOKtMfaGiRUcgb4XTNoa0pGy7hgzh_ZsbVw92ZJVa4Dl5BF2Y8unNQRYOKJZns57vBGdizzuJeVy2x0fS_CLkBXXGroM1RMmggtIj5K7Fk-aZAbWhzIwwJgTqr4An24vyF6hvhdRpkFNc_TOgwDeFRAAjgDRUbOn0MwE0pPPONPXL7neOIWvWbJGNHsWf69dubMB5ieYiwg-Bc0WJ56GAjtHuv7duYWCx5AWpnyUpIzBKqo5ZI07THce_25B11BaHVJNg4Xj5XqC1Jm4stsniNTMJ2BXGLKrYAGrpMQ9ekJtJxlT3q5E5Ssevw6fIafoVnJs_IETF65DBuAGWPeTNEl5ZQwKLSMtCY6wzHwGBud1z36T88q7zAB9lqlQdCtUukvcITkduYkZGgD_gF6NowCYeo2BMcvSAHnvOFqin2Oaw_oh-Npz7k=w608-h159-no
While the FSM illustration is maybe a little confusing, I am assuming with the 3.4W bulb, the needle should sweep all the way to high based on the verbiage in the FSM. Well, while mine did sweep a little, which gave me hope, it fell short of making it to high (you can imagine the excitement as it began to move, and then total let down as it stopped short).
jLbNijO6R324KR5wY8gNl8WuRy-xcg95DEkO0Ab4QrpQcOvNFuu01cfoRPWvzA2AFyKr4FExg7Q79GxeUelUblBZO-ZFympgHSHZRfj_GoCqH4SH5KNxSzl-vB7L7mNoA9CQcyN7L9qPDODASWLWJcj10_-JRSUYBrrOic5RLOlkBNYBUk6OYf8_YnEJ0B-ju23gpMhIiJ2tCPQT2UOysx9MM0WO93Nfg910bJag7SitWr6T-2UWEU8fHNtxXC84-IL-DrH7HKtZ8DOrKfQLf5GXuAX7AeORZcDVnC--h4GXVvNF-9qAp8EBpOS6Sob6iQUAapuKkrDtkbTE1bkU2ZBPwhD44DQyoJHx60SBpHYaSU5-LRJBT8go4mwUT-tXF5syblYGdODOyU98tiB2lRHZJA8w-cOOiS8RFXnQFnpAeN6FLTIdOqzsx4joRxnxxoDr9xoUv9fIAyhcprjoyIB1Qm-sGRUvmUeDwbZtOhCVZE1-gOTDs-t4L-JdOOlTlcsw-K6XOoo8rDZTZ6Z-qWwYvQ98qiBYZPG1X4erEzAYD2wx3Od74ngswRsCm2Rjz_Lm3_jaoZGmxyOUZmdFnW7MXLdsNgqTyVTySdE=w1312-h984-no
After doing some digging on here, I found some pics of people’s gauges with the engine off. While most people’s oil pressure needle rested right at the first mark when off, Mine well was well below.
-ORn4A6D_b0_gRnx8yBRDA5odi-dqtGIXbzm-Vkq0Md2jHCxzaCxR3wMNvLytqystHGiVc-x2kq22AIFflHz1QsIqjW2LvpvcFN2gqL6U7M7cLxneNoiZvd799X9g9smVgZQsm7-ABWb2k_NCJBKZtSFCn-Psa47meFKiBYnj8UxeskirwvmHGqLu6jPV406QIyPhR-JuQxjL3DpP3JHlz6L4LjNM0Qc2kIw1Jf93x01FpkmF75W-eaAUnEaQfhLcNWU0i3v8kappbBZyrd1G98Z80uSsMNVdAGjIy1GdEg0QfgsxoW4j0xuBXuOdQX2qij7bux6VKM-F0frFHllsN1XkJmm0CoiDQHVCNdz37ERXQkI8tzilDdu5VB_fY0jGW3hTFiC1HbknZwvrJaF9O4_VvFcwgwfv2-s0kVAdNlMY_rk_HlaELGorXXm6jpDq3Dx9XbYpJAUBoXS4MfjAAFaUlmI3mydVO5F2c19_is906Lw2SCJqDCL-bXdr_j2RHOZpmR1G14F2ACJvO9JnhSXcJqnsVKHzcwrmIKy8SNiwTAmKM7t9LV447ZNHFRxxYNdXxG3f47R7p58doFx2ruThqysQV-6RizxhdI=w1312-h984-no
So, the next step was to test the gauge resistance in the back of the combination meter aka cluster.
oocWQNfTaJasFLjP2bA1NrauKLX04MfF3SLZkYHj0aUl2AYstejIN5PN73hxRRTI9UXs2B7GCr9qXLiP9OyoYLU6QdMz4QORUaI8H0t0w7I45NAMyOVfRZd8QO62eL3--blfMxO44ptgRIQRhjRKe-j3kHLAx-tKExgSTAXr78bQjrGUZ9cQingJhDsql6_Mjpk3TPXLxzESkwWXDBwwqe1DCVd2_DGxTst6uSErAmU641wELNan2HA04-101GlGwRs3JB6rg-Of940N_0Z0Xh_kW5jUMSepF3fiyPjmoN8jCz_rklUADvKiTPiobhwris5sZpZiplSoeggb03_j7GVnmi6bHwunAraCPVqiGOA2zoCmxLsKqfRrrtIFO5LTghkBc81HEM1lOzEs9wK4TOXAaWOqmJmECiKTOv_g-4rl40fkINYynvH4BmT2KZnCopNx-zMDX8bqVjuc4YMlVJl--Cp2qPMxFShkHO2e-7wC6PczCK0NSvSzaH7KpdNBEhxUbiMT_QXEdE-O16fziSfwiNucZ7l9grCf02fTBvoWOrmeArjHLr1RN6AUPmTByoU60qitGOTxa3RgEDKFyXi0kQq4TL7fk9UQyB8=w620-h171-no
I really like to know how plastic dash pieces come apart before I dig in because if you think something is supposed to pop off and it’s not, you end up breaking plastic pieces, which is always heart wrenching… I found this great video on youtube that someone made on the cluster removal (if it was someone on here, THANKS it was very helpful!):
Once the dash was out, I again used the FSM to test it.
vFUkrgaEaTrZBBnvwJ7X4_WWx9h_iWBffyXJBfFu10PeWJsfx1pRSpE7ppAPKaFoZauwlz6qzGIoiV_dkbANdpJKDmo67iSyB8alH4TcG0rXggYx_mc3tpQxNPvsp_IckFWzixSO5PWAJEef1D4AwiIlaCK9N3uMh5KNlwPPJ3WVxMNQABpPdGCY34kE-GGRKZsKqyAVUhd9KcAaal1R8KtrjeAC6B52epQ7Zs5h_uin9geU6u2wtG3Cw6jGRv3F7OX6lvoAo5xpJnwmZOGrbnp0vhTLkkiC_WgvdML3Ek8IpuGub06-YjSE0FtoES4jKmudS3SwQ9A0MTZGuJgzkM8VlJMvZsyY1I0Gux-TID5eDrLKldcPu6I5KRuxpPPevAZtbwSbN-xPgwkDcCUfDgdDvsU9zUwdtCnQJZfzh9KNGBt7FCdWMs4qvFksRZ4UjClU7OcaXwNZ93elixs6Ldm3TKRtN2wMRODrRqxUMMXffxo9x-tYZAqa1LnFy-5isrG-mfLM52ad1Z-iKze2nD384n5ZKE2I91_8_gcn3uIGxsl6Y9778tWG7JzaecQ3CeJwNHx8uceerGcU06XJF4TCfZl1dDVEBzQ55KY=w738-h984-no
Based on the fact that I
1) had an in spec Ohms reading on the gauge
2) the gauge needle did move (though not much)
3) the resting position of the gauge was really low.
This led me to believe that when the wire grounded out while I was driving, it had buried my gauge so deep into the negatives and bent the internals of the gauge such that normal oil pressure wouldn't give it enough signal to lift off of zero. I decided to try to adjust the resting position of the gauge back to where it was supposed to be and see if that helped. To do this I had to remove the gauge from the cluster. This is done by:
1) Opening the cluster, which involves releasing the plastic tabs connecting the cover of the cluster. There are some on top bottom and both sides, so gradually and gently as to preserve old plastic.
2) Once the cluster cover is off. Remove the screws on the back of the cluster that are associated with the oil pressure gauge.
3) Once the screws are removed, the gauge can be gently pulled out.
With the gauge out, I was able to twist on the circled piece in the below pic until the gauge was resting at the first mark on the gauge.
uqDq0tMPE9xbjd4kEBbLTnSSBq1J7FYd9eQyLV1Olm1ZUKNnmJ5o8_KYeeAdvemfd9J6gaN8gp1wUHFuj1BBT0havkNal9dhHNPX-eYPjsRk2KdHiRbk8zGUp1s_c9tzW3d3bo5O5xlTu493ddvZQsRKEHrCzmwS8P9m3SBWb_GYPj2iXdrHr6aaK9cDj5ze7Ck5v4frLdBf00op2hdE9EbnamH2fTtM21sIJ1fTUOV40-vJiWkPZv5j3HKgoYAgIMfFLGRzd28VPX7pUoSl1wMn3eaVB9_uz9G0zwLKsRh41k2h6_b4C1BDLkR0O-d4qA1opSHwbAOeYY5aKidtoQFPUvxdYmv9UXrj0isdzjSpZLMT6ui4sODE6RKTxZTidwe-MNz6yNI-ktZAzssd0SF7PZCp503CuerSpxjzeS5-EOZDlAOrRVqjjX6tuxOIB-ipwXqZKr59JNIUZyTB0IIPqffZHOImWbY2EhSto1G1GOOjpQ99j0awn11xVJf8mSr3IZDZDqn8CmW7b6kN4e73N3dE4C21XLu7z6Bp6JBRhqaEfkXSWT3M8TSOTPfSdZal0CM9g28CuVySdzsUzysjl6lvElcefuFQbr4=w738-h984-no
Once I did that, I checked the ohms again, and I was actually a hair above spec post adjustment, but I decided to roll with it anyway.
Once reassembled, I test drove it, and it has been operating perfectly. In all honesty, I didn’t expect the gauge to operate in the same range as before, but as long as I had some repeatable operation, that’s all the accuracy I really see in the factory gauge anyway. So, I would say I’m super pumped at the outcome! I dug through the bowls of mud when I was trying to narrow down my problem and avoid buying another gauge, and at the time, I didn't see where anyone tried this. Hopefully, this thread allows others to give it a shot if you have similar test results.
Were you separately verifying oil pressure? And does it still go to Low when you are stopped?
I did not separately verify the oil pressure though I agree that would be the only way to be sure you had good pressure. I just wanted the gauge to have repeatable operation and since it was operating per spec prior to the wire breaking loose I wasn’t worried about my true oil pressure. The gauge does return to the first mark when the engine is off.
Your Oil pressure sending unit may have 2 Tabs
one for the center brass button
the other is for a Stand-alone ground wire spade connector
Do u / Did u have a 2 Wire oil oil pressure sending unit ?
u mentioned knocking off a wire , if u knocked off the ground TAB , u will not gave any gauge function
@Red Merle
The wire that was on the brass tab broke from the plastic connector. Whenever the loose wire end grounded on something around it, it was spiking the gauge. I’m assuming it eventually grounded on something for too long which caused the gauge to peg hard enough to bend the metal actuator within the gauge.
@Red Merle
Do you have a pic of the bulb and pigtail?
Interesting thread, I just got a new sender but my gauge doesn't work. I'm not clear on which of the two connectors goes to what part of the sender (there's a post in the middle and a tab on the side, white connector and black connector). Whatever I did I think I screwed up the gauge itself, or it has been screwed up. Gonna look into it further but thanks for the info.
I’ll have to get one when I get back home. My son broke the bulb so not sure I’ll have one of that. I will say both items were sourced from the basic stuff on the aisle at advance auto parts
I ground out my oil guage by mistake and the mechanism did not read properly afterwards, so took the guage out and realigned the pin that operates the needle.
One thing that people do wrong is set the needle to zero, when not connected to the sender, to be accurate at rest the gauge has to be connected up, ignition on, engine off, battery connected to mains battery charger, with a working voltage of 13.8 -14.4.
I then spent a little time calibrating the sender to the gauge, did it quite a few years ago now, still working perfect.
My sig has a link to my long running thread, all details on the correct procedure are there. FWIW, I put a T in the block, I now have an oil pressure light switch (set at 20 psi) and buzzer, gauge responds too slow in the event of oil pressure loss.
Regards
Dave
Regards
Dave
I did that same thing!! Grounded it out and now it won't read anything. Thanks for the info
Ok, here's a pic of the pigtail (with broken bulb still in it) along with a pic of the bulb I bought. Update: not sure why my pic linking i not working on this one but did on the other. I'll work on it, but in the meantime; here are links to what I used.:
pigtail:
https://www.oreillyauto.com/detail/...rker-light-socket/85814/4176837?q=85814&pos=0
bulb:
https://www.oreillyauto.com/detail/...ndescent-bulb/158llbp/4743153?q=158llbp&pos=0
contentRedirection
contentRedirection
pigtail:
bulb:
contentRedirection
contentRedirection
Thank you much sir!
Thanks for this write-up. I have a dead oil pressure gauge as well, so I'll definitely reference this while diagnosing for repair. Thanks again.
I have these Available ,
Both for Single & Double Ground TAB Wire Applications ...........
How much?
Below are 2 separate Links ,
- 1 is the Double Wire w/ ground Tab
- the other is the Single wire version
please click on each one to see the differences
On the FZJ , The Early Sub Harness 82221-60010 , that covers : Is Discontinued
ToyotaLand Cruiser1992-1997
  • 8 Cyl 4.5L
1FZFE; 1FZFE; FZJ80
On the FZJ , The Early Sub Harness 82221-60020 , that ONLY covers : Is available
ToyotaLand Cruiser1996-1997
  • 8 Cyl 4.5L
1FZFE; 1FZFE; FZJ80
