hi all
I have a 1985 rj70 22r bundera
the only wire i can find near my sender is black and bare wire ?
am i right in assuming the bare wire is the ground? and the black wire is the centre?
finally got the car back
here is a photo of the wire
I put the lugs on myself
there is a aftermarket gauge installed I am not sure if the original gauge is working either
forum.ih8mud.com
I wrote up my harness diagnosis and rebuild (1994 FZJ80 1FZ-FE) here:
Oil pressure sender
My oil pressure sender has a broken wire, possibly a ground! Anyone know where it goes as there are 2 plugs?forum.ih8mud.com
After putting the rebuilt cable in my gauge read consistent with the owner's manual (see pic below). The "funny box" had a toyota part number and as I mentioned in the post it comes up as a "filter" used in the power system for earlier model truck stereo power sources (I think). It was in there when the gauge worked so I left it in. I am not good at electrical engineering so won't even try to guess why it is in the cable. View attachment 2657457
I would like to comment at the outset that CruiserMatt's harnesses look very nice. And the prices seem very reasonable. If I had more time or I had not already redone my own harness in very non-OEM form, I would be sending $$.
So just to share where I am in the process, I replaced the sender/sensor with a new, non-OEM one, and still no effect that I could readily see. I decided to try the second test with the light bulb load to manually drive the dash gauge. I really did not want to go out and buy yet another thing for this so I hunted around and tested a few 12 volt bulbs. I have replaced most of the instrument cluster bulbs with LEDs so I had the old incandescent bulbs at hand. It turns out that the large green instrument cluster bulb (at least the one I have) drew .22 amps for about 3 ma at battery voltage. Close enough and lower amps so it would not destroy anything in any event.
With the ignition on the bulb glowed dimly, as you can see in this photo.
Here's what the dash gauge looks like with the ignition off:
And here's what the gauge looks like with the ignition on:
I infer from this that the wiring is working but the gauge is faulty. Maybe it got grounded out and bent like others have reported. Or maybe it's just gummed up from almost 30 years of being in the desert. I'm going to take a long drive tomorrow and watch the gauge. I know there is oil pressure, so I'm not worried about driving it. I don't really want to pull the cluster out yet again because we are about to take the truck down to Florida on the Auto Train for my son to use there and I have a junk cluster back in Dubai. I think I will just let this particular sleeping dog lie until I have a spare, verified working instrument gauge to swap in.
I want to mention again for the benefit of others that the large green bulbs in the instrument cluster work for the second test in the FSM.
John, This is Will across the way in Bahrain. I recommend you stop running your engine and open up your oil pan. I spent 3 weeks chasing what I thought was a bad oil pressure sender and wiring--same problem- I was watching my oil pressure gauge slightly move. I was too late ignoring it and I caused major damage to my engine (rebuild and 6 pistons later). My oil pan was full of soot and at the beginning of start up my oil pressure gauge moved up slightly because the oil was clean and cold; however, once I idled it, the soot got loose and clogged my sump inlet strainer causing needle to go down. From you pictures, I truly believe you sensor works, you just have low oil pressure. I will post my nightmare photos shortly. My rule of advice- if your needle says its low oil pressure--assume you do.
Hi William. Thank you for the advice. I take your point. I will say that when I did the lightbulb test the meter barely moved which suggests the meter itself is stuck. That said, this is a desert truck and it shows signs of heavy use. I'm going to heed your advice and measure the oil pressure. I happen to have a transducer handy so I can see with some precision what the oil pressure actually is.John, This is Will across the way in Bahrain. I recommend you stop running your engine and open up your oil pan. I spent 3 weeks chasing what I thought was a bad oil pressure sender and wiring--same problem- I was watching my oil pressure gauge slightly move. I was too late ignoring it and I caused major damage to my engine (rebuild and 6 pistons later). My oil pan was full of soot and at the beginning of start up my oil pressure gauge moved up slightly because the oil was clean and cold; however, once I idled it, the soot got loose and clogged my sump inlet strainer causing needle to go down.
Input: 0-100 psi
Output: 0.5V~4.5V linear voltage output. 0 psi outputs 0.5V, 50 psi outputs 2.5V, 100 psi outputs 4.5V.
Accuracy: within 2% of reading (full scale).
The tricky bit is getting the 1/8 BSPT Male Thread to 1/8-27 NPT Female Thread Port because Mr. Toyo decided BSPT was best.
