lowtops said:Would it be feasible to just drop the front axle to remove the pan instead of unbolting the motor mounts? I plan on installing a lift in the near future and this would be a perfect way to kill two birds with one stone.
alia176 said:Rookie2
>What's that hoist setup.. is that steel beam in your garage?
Yes, that's an I beam in my garage. Mighty helpful for doing this type of work!
Rookie2 said:Nice! It's hard to tell how you've got it supported. Is it bearing on masonry walls each end, or are you somehow hanging it from the floor or roof system above?
Rookie2
The oil pan is back in place with a few bolts until I'm ready to take it off and re-seal it. Being a smart ass I thought for sure I could take it off without lifting the motor ah-no! I will try your method as soon as I'm ready let you know. Thanx again.George,
I think that should work. If you haven't removed the lower oil pan yet, then use a floor jack and a piece of 2x4 under it to do the same thing.
Goes w/o saying, be safe, especially your eyes!
Cheers.
I didn't seal the pan yet but I do have the square rubber gasket for the timing chain cover.I read the description of your oil pan reseal and was wondering if your replaced the square o-ring at the front of the pan under the oil pump inlet. It seals the pan to the oil pump. Getting FIPG in therre might not be so good for the pump or other small hose throught out the engine.
You can also undo your sway bar to give you some more room to get the pan out. You could also try jacking the truck up and leaving the axle on the ground, moving the whole engine away from the axle. Undoing the front lower shocks mounts could help with that. Watch your brake lines and ABS cabling.
Just to reiterate, moving the axle away from the oil pan WON'T HELP MUCH It's the **&^%$# panhard rod support bar that gets in the way and it's AIN'T MOVING! Please see the pics and descriptions at the beginning of this thread to see what I mean.
Now back to your regularly scheduled program....
Also watch out for the fan blades, make sure they don't hit anything when you lift the engine.
I have seen lifting the engine by jacking the crank pulley. Good or bad? I don't know, but I have seen it done this way. Also watch out for the fan blades, make sure they don't hit anything when you lift the engine.
