Oil line broke! How can I fix this?
SW Washington, USA
Website
instagram.com
Pics say it all. What are my options? Does anyone remember where the bottom of this line goes? I'm dreading taking my lifter cover off... I really hope I don't have to pull the motor to access it. Any help is very appreciated!
Cut it and a compression union?
Or get a replacement tube from SOR. on "THIS" page, click on the left tab.
I sent you a pm.
Besides being Metric that a pretty small tube for compression fitting. Personally would use small tubing cutter cut the section out. Use slightly larger piece of copper tube and use it as a coupling. Could get away with soft solder versus Sil-Fos or silver solder. Done this many times on cap tub air-conditioning units.
Only the side cover needs to come off for a new line -
Or you can try to pull out the tube so you can cut the tube and get a compression fitting on as Skreddy said, but you run the risk of getting bits of copper in the lifter area and the tube touching a push rod.
Pull the battery, coil, PCV and take off the distributor cap and wires, not hard to take off the side cover. Make sure you have a new gasket as well as your favorite scraper/cleaner setup handy.
