Official ONSC member buying/selling thread (1 Viewer)
Here is one for $2-3K less ($8K) than those with 218K miles and in pretty nice shape:
1898398
  • Very little to no rust underneath - light surface rust on rear 2" hitch
  • New 305/70R16 BFG AT KO2 Tires
  • OME 861/862 Stock Height Suspension
  • New Radiator by Mt Airy Toyota, pro install. New front brakes/rotors at that time
  • WeatherTech floor mats front/rear/cargo
  • New front/rear struts for hatch/hood
  • Repair Console Lid - New Leather
  • Updated mechanical seats - very comfortable - no more broken gears
  • Full PM and baseline - Lots of new hoses, valve cover/disti gasket/rings
    • Xfer Case, Diffs Synthetics at 212K miles
    • PCV Bypass filter
    • Sandblast/ Paint Valve Cover
    • Rear Brakes Pads 04466-60020
    • Heater valve 87240-60170
    • Valve Cover gasket
    • Distributor O ring 90099-14118
    • 1/2 moons 11183-50010
    • spark plug gaskets 11193-15010
    • new spark plugs 90919-01176
    • Inspect plug wires. Resistance test ok on all 6 wires.
    • check disti for oil and clean
    • Check Tie Rod Ends or other steering issues. Tie rods test OK.
    • Repack bearing, tighten wheel bearing nut.
    • Window Runs 68141-60010. 68151-60010 68142-60011. 68152-60011
    • Door Locks clean
    • Repair Mirror wobbling (Driver side, Passenger is ok)
    • Clean Throttle body, vacuum ports
    • Clean Carbon from EGR intake runners
    • Check All Vacuum lines/Replace as needed
    • Replace charcoal canister rubber hose 77754-60180
    • Replace EGR hose 26595-66010
    • Replace water bypass hose 16264-66021
    • Fix D Light
    • Replace power Antenna w/manual 86300-60030
    • Discharge AC to remove AC core for access to install antenna. Replace exposed o rings.
    • Vacuum the AC system and recharge.
1898397
1898399
The Bad:
  • White paint is discolored in spots
  • small crack in driver side front window in the last inch or so of the bottom corner- does not leak
  • Steering column moves up and down kinda weirdly
  • General condition of carpet is "good" not great
  • Driver rear door has to be manually locked/unlocked
  • 2nd and 3rd Row seat leather is good with no rips, but not perfect
  • Transmission oil pan has had some rough-looking welding done to it, but looks to be very strong
  • I have detailed pics of this stuff - send me your email and I will send you the Google Pics Shared folder with lots of pics
Few more pics:
1898409
1898408
That price tho
That price tho
Crack smoker.
Now, i am selling one of my 80s. After seen this prices i just want $4500 obo for a salvage title colletors edition. No lockers, 250000 milles. Pm me for more info
Yea - Price just went up for my LX . . . $15K on eBay now, sorry friends.
@Roxx, @weejub Ya'll will have to hand wash your trucks to get anywhere near your asking prices. Crack dude from Dallas has set the bar high.
No, no, no, i am selling the dirt too. Barn find!!!
Luckily for the buyer it doesn’t have chicken crap. It will be worth more
@Mtbcoach
Prolly not what you are looking for:
Sneak away to the auction with us Jamie @weejub
Expand your addiction :)
Cheap for aluminum.
@Mtbcoach
Thanks Jamie, but yes, a bit too new 🍺
i wonder if these will fit the 100 - baahaa
with a huge body lift/sawzall mod and very big spacers i'm sure you could reign over all at 36 hours of uwharrie.... make sure you have about 14 spare CV shafts
This is just about my ultimate daily driver. The 6 speed and supercharger is enough for me to ignore the relatively poor reliability of the bavarian brand
My ultimate would still be a 6 speed S8 from the same era though.
Those tires are 46.44" and weigh... without the wheels.... I'll give you a second to guess....
...... Thinking....
Well....
You're wrong. They weigh 219 lbs EACH. WITHOUT THE DAMN WHEELS..............
