Nice. It is hard to tell, but it looks like if you had a second box, that you could fit all that gear in there and just stack them. Do you think that would work? Also, do you still have a third row?
Yes I have the third row still installed. And there is a little space still available even with the 3rd row up and reclined. I could put a smaller front loading box under the larger top loading one. And I may do that...currently I’ve got it set up the way it is so that I can take the 4 max trax (currently on top of the folded third row but under the floor mat) and place them on top of the toolbox should I need the 3rd row.
the max trax give a slightly more level platform across the 3rd row when it’s down.
the back of the truck is a mess in these photos-I had just purchased the toolbox and was seeing if it would fit...no organization had happened yet.
with the toolbox I can fit quite a few things that now won’t fly around my cab should I get in an accident...plus there’s space between it and the third row that I can fit a spare cv shaft, starter, max ax, max tool kit, and a few other soft items. and the extra parts are wedged sort of under the third row when it’s down so they’re not going to fly around in an accident either. You have to raise the 3rd row to access them-which is fine w me. I won’t need a spare cv or starter often.
Basically everything I would take on a road trip/off-roading trip fits in the box or just in front of it...I don’t have to load anything except camping equipment or luggage if I’m going some place far away.
if I was going to do it again, I wouldn’t buy the 48” version with the little shelf at the bottom (designed to sit on a pickup truck side rail) though, I’d just get a full 48x15 one for the back of a truck. I kind of like the little cubby for putting my quick access recovery stuff...but I’d probably be able to keep it quite organized and gain a little space had it not had the little cut out on the bottom.
The little cubby isn’t so much of a deal breaker that it’s worth returning and buying another one though.
if I did it again, I’d buy this one:
Stark Industrial 48-Inch Aluminum Truck Underbody Flatbox Pickup Tool Box RV ATV Trailer Tool Storage Lock with Keys
Amazon product ASIN B07Z9NMM65
