Anza Borrego
What tires and size do you have? Did you do the sensor lift? I have a '13 with those times except they have the milled front. Your rig looks great!Anza Borrego
Yes! I have that problem too. Let me know if you found a way to solve it.do you have a hard time getting the ikamper closed? I can see about 1/4” of frame under the straps, same as mine.
Tire size is 285/70R18, KM3. Yes, I do have sensor lift on it.What tires and size do you have? Did you do the sensor lift? I have a '13 with those times except they have the milled front. Your rig looks great!
I love it, and have already lost track of the number of nights we’ve slept in it (I’ll probably go back and try to figure it out at some point). It’s the only hard shell that unfolds to the size it is (actually, there might be a few knockoffs hitting the market now).
Pretty good. I saw you can get the ARB frame mounts with crush zone separate from the bumper. Would be easy to stick a winch cradle on top and add plate to taste.Installed a free winch... with photoshop. Playing with the the idea of an HWM and hybrid lower bumper. ~100lbs. Hrmm...
You need...the Insta-winch!!!
Thanks. The pic makes it look like it was taken from far away and that the formation is huge, but I was actually only a few feet away from it and it is about 7 ft across. Many of the formations were miniature size.This is a great picture!
LOL.. That's awesome. Would save me 95 lbs off the front end!
Beautiful truck! If ride quality is what you're after you should go with the P Michelin LTX. KO2s will ride much worse. Even LT-Michelin LTX vs KO2 there was a big difference I've had both.I have 18" black Tundra wheels, figure out which tire I want - 285-60/18 in a P Michelin LTX? Or 285-65/18 in an LT maybe a KO2? I am unsure what the trade off in ride quality will be. Better because 21 to 18, but worse because aggressive tread and P vs LT. Any advice here would be appreciated.
Thank you for that. How much of that do you think is offset by going from 21 to 18 and having more rubber?Beautiful truck! If ride quality is what you're after you should go with the P Michelin LTX. KO2s will ride much worse. Even LT-Michelin LTX vs KO2 there was a big difference I've had both.
Congrats on the new LX and thank goodness you did not get hurt in the accident.Thank you for that. How much of that do you think is offset by going from 21 to 18 and having more rubber?
If I go with the LT Michelin, there are more sizes available than if I stick to P.
I did 275/70/18 LT Michelin Defenders and loved them. 285/65/18 is cool too. 295/70/18 is available too but will require some work to get it to fit.Thank you for that. How much of that do you think is offset by going from 21 to 18 and having more rubber?
