Media Official LX570s Picture Thread
Photo/Video/Audio threads
Was that pic running up the hill the sand dam at superstition? Fun hill! And yes, I agree that 295 as a solid improvement over 285s, performance and visually. Flotation! I was running at 12 PSI when I was on that hill and she was unstoppable. Want to try with 35s.
Your LX has a lot more suspension flex than your friend's 4runner.
If I'm not mistaken the 4runner is even lifting a rear.
Blow sand hill in ocotillo wells. Up the steep side.
Yea my brothers TRD with lots of aftermarket suspension parts. I think if he took the sway bars off it would help. My old runner...
I’m running the icon wheels. I don’t remember the offset but it’s in a thread somewhere. No rubbing after taking heat gun to fender liner.
I plan on going to 4.88 in the future and will go with 315’s “35’s” and put a front locker in. Super happy with the ahc besides having a issue in December what at Moab. Turns out I was just below the min level for ahc fluid I think due to adjusting my rear sensors higher.
Just liked the way it looked leaving this customer’s home. Parked in high.
It might be slightly noticeable that I’ve begun to cut into the trailing edge of the rear fender/Tupperware bumper but I haven’t finished cleaning the cut yet and the hitch cover doesn’t fit securely since my body lift. I need to work on both of these things.
Some photos of my 2011 on 275 60 r20 k02’s (no spacers), my hitch mounted basket (with a riser so I can tow under it), and 48” truck toolbox (fits all my recovery stuff and tools while allowing full use of 3rd row).
Cool setup you got there. Join us in the thread as there's several of us exploring this strategy.
Wrong thread...
Nice. It is hard to tell, but it looks like if you had a second box, that you could fit all that gear in there and just stack them. Do you think that would work? Also, do you still have a third row?
Yes I have the third row still installed. And there is a little space still available even with the 3rd row up and reclined. I could put a smaller front loading box under the larger top loading one. And I may do that...currently I’ve got it set up the way it is so that I can take the 4 max trax (currently on top of the folded third row but under the floor mat) and place them on top of the toolbox should I need the 3rd row.
the max trax give a slightly more level platform across the 3rd row when it’s down.
the back of the truck is a mess in these photos-I had just purchased the toolbox and was seeing if it would fit...no organization had happened yet.
with the toolbox I can fit quite a few things that now won’t fly around my cab should I get in an accident...plus there’s space between it and the third row that I can fit a spare cv shaft, starter, max ax, max tool kit, and a few other soft items. and the extra parts are wedged sort of under the third row when it’s down so they’re not going to fly around in an accident either. You have to raise the 3rd row to access them-which is fine w me. I won’t need a spare cv or starter often.
Basically everything I would take on a road trip/off-roading trip fits in the box or just in front of it...I don’t have to load anything except camping equipment or luggage if I’m going some place far away.
if I was going to do it again, I wouldn’t buy the 48” version with the little shelf at the bottom (designed to sit on a pickup truck side rail) though, I’d just get a full 48x15 one for the back of a truck. I kind of like the little cubby for putting my quick access recovery stuff...but I’d probably be able to keep it quite organized and gain a little space had it not had the little cut out on the bottom.
The little cubby isn’t so much of a deal breaker that it’s worth returning and buying another one though.
if I did it again, I’d buy this one:
Stark Industrial 48-Inch Aluminum Truck Underbody Flatbox Pickup Tool Box RV ATV Trailer Tool Storage Lock with Keys Amazon product ASIN B07Z9NMM65
Are those 18" Tundra wheels?
And if so, what size and type of tire do you have on there?
Yes they are. They are the 275/65r18 Michelin AT2 tires. They were something I threw on to replace the awful 22s that came on it.
I am getting ready to order some new tires to put on a set of RWs that I have.
The Michelins have actually done really well. I am always nervous that I am going to tear out a sidewall on the sharp rocks out here but they have held up quite well so far.
Thanks. I have the black version of those wheels ready to go to replace the 21s, but still trying to decide on tire. I pretty much decided to go 275/70r18 and E rated, but I keep flip-flopping on what tire to get. I am mostly pavement and snow. But want the light off-road when I need it.
I loved the Defender LTX on my Sequoia, so thought I might go with the A/T 2 as a replacement but still good road tire, but they aren't reviewed as well.
And then I see all kinds of positive things about the Nitto Ridge Grappler, the Geolandar, and the Toyo AT3. No matter which way I go, I want them to last for a long time.
I think I am going with the Toyos. Just need to pick a size and order.
Are you going into the 34" range? Kenda R/T 35x10.5x17 or Goodyear MTR 275/80R17. Can't argue with the Toyos either, do they have 285/75r17 in that model yet?
Both are great! With the right offset both fit with minimal work.
