The high hc is going to be from unburned fuel. There are a number of places this can come from.
A rich air/fuel mixture, misfire, too much fuel pressure, float level too high, leaking accelerator pump, choke not working properly, etc.
You asked about finding a missfire before. You can usually see the engine running rough. An easy way to check is to use insulated pliers and pull one plug wire at a time and watch the engine. When you pull a plug wire and the engine stays the same, you know you have found the cylinder responsible for the missfire. Normally pulling the plug wire should make the engine stumble.
I looked through my mityvac to find the diagrams, but I have no easy way of getting the manual to you. They list all the manuals online, but mine does not say what the model number is. They have great charts that will show you all kinds of things your vacuum gauge can tell you including valve leaks. See if you can find one of these charts.
