ADVENTURE / OFF-ROAD / EXPEDITON TRAILER
“The “Condo” a nickname given by fellow off roaders at Pismo Beach, California
The Condo is at home in a campground, the mountains, beach or desert. Just imagine, after a great day of off roading and exploring, come back to camp, have a hot shower and sleep in a very comfortable air bed. At 11 feet long with a full stand-up size tent, it sleeps 3 people with easy access storage space to spare.
Built around the principle that you can hook up your tow vehicle to a fully self-contained trailer and head out into the wilderness. Want To Climb A Rock Waterfall, Travel Thru Deep Sand To Your Perfect Beach Hide Away, If Your Vehicle Is Stout Enough, This Trailer Will Follow You!
Solar Panels charge the batteries while you spend the day four wheeling or exploring. Only used a few times, trip log available, this trailer is in excellent condition with many nice to have features:
· Battery Monitor.
· Custom cabinet with sink, hot and cold running water, includes microwave, refrigerator and storage for the Porta Potti, Generator and other items.
· Queen Size Mattress with electric air pump and remote control.
· Custom convertible sleeper/couch (single bed).
· Custom Carpeted cabin.
· Cabin and Exterior Lighting.
· Backup lights remotely controlled from tow vehicle.
· Heavy Duty Chassis, refurbished service bed (epoxy paint), 4 inch lift, locking tailgate.
· 6 Locking External Cabinets to hold all your gear.
· 33" x 12.50” x 16” M/T Tires, 3 each, used once for a short trip of 25 miles. $1200.00 new.
· 16" Alloy Wheels, 3 each (new since some pictures were taken). Bolt pattern fits Bronco and many Jeeps.
· 3 Axis Off Road Tow Hitch (new since some pictures were taken).
· Dual Deep Cycle Battery System with “charge while you drive” cable.
· Solar Panels, keep the batteries charged while you spend the day four wheeling or exploring.
· Honda generator (quit, light weight), charge batteries, light up a large area or run power tools if needed.
· On board battery charger (plug into house current), batteries can also be charged from the generator or the solar panels.
· Inverters allow 110-volt appliances to be used.
· 110 volt and 12-volt Power Outlets.
· 18 Gallon Water Supply.
· Tent, External Shower / Porta Potti.
Please see the full list of extra items included with The Condo. You would need to purchase most of the included Auxiliary Items (approximately $1500) if you were buying a new trailer.
It has most (in some cases more) features of new adventure/off road trailers starting at over $40,000. Price $16,500.
See pics on this link: https://orangecounty.craigslist.org/tro/6619539678.html
An Owners Manual with operating instructions for components is included. Written procedures and tips for trailer setup and maintenance provide helpful hints for those not familiar operating a self-contained off-road trailer.
MAJOR COMPONENTS:
· Bed, Service Truck, 6 locking external cabinets, custom tail gate, epoxy paint
· Camper top, Wildernest, pop up tent, 7 windows, maximum headroom, plenty of room to stand up to wash and dress.
· Chassis, heavy duty, boxed frame, 4-inch lift, overload springs
· Front Power Cabinet, 2 deep cycle batteries, inverter, converter (battery charger)
INTERIOR COMPONENTS:
· Battery meter
· Bed, queen size – air mattress with air pump and remote
· Bed/sofa – folds for travel
· Cabinet, front, sink with hot/cold water, microwave, refrigerator, storage
· Carpeted interior (custom fit)
· Cushions for bed/sofa
· Entry steps (fold down)
· Fans, 2 each, ventilation, can be moved to any location.
· Lights, 12-volt, 2 each, 1 each magnetic mount, can be moved to any location.
· Light, 12-volt, permanent mount
· Parking level gauge, large, visible from tow vehicle, no need to get out of tow vehicle to see if the trailer is on level ground.
· Power Outlets 110 volt and 12 volt
· Temperature gauge, inside and outside
· Tissue holder with tissue
ON BOARD WATER SYSTEM:
· Faucets, sink (inside cabinet), shower head and hose (outside)
· Fill/drain kit
· Hose (coiled) with nozzle
· Propane tank, valve and plumbing to water heater
· Water heater, propane, 6 gallon tank
· Water pressure reducer, 25 PSI
· Water pump for sink and shower
· Water tank, fresh water, 12 gallons
ELECTRICAL SYSTEM:
· Backup lights, 2 each, remote control from tow vehicle
· Batteries (deep cycle) 2 each
· Cable, “charge while you drive”, charge trailer batteries by tow vehicle while traveling to destination, uses standard Anderson Power Pole connector.
· Circuit breakers (resettable) for the water pump, inverters and other components.
· Converter (battery charger) mounted inside Front Power Cabinet. Converts 110 volt house current to 12 volts with external plug to use with extension cord.
· Inverter 12 volt to 110 volt, 2 each, 1500 watt and 300 watt
· Master power switch (external) with lock
· Stop, turn and tail lights with standard cable and connector to tow vehicle.
EXTERIOR COMPONENTS:
· Exterior compartments, 6 each, magnetic mount LED lights in each compartment
· Faucet (exterior), hot and cold controls, shower head with quick release hose
· Hitch, 3 Axis, custom
· Rock screen, front window (custom), folds down for storage shelf
· Skid plate, rock guard, water heater (custom)
· Shower tent / toilet enclosure
· Spare tire carrier with lock for spare tire
· Stabilizing jacks, rear, 2 each, long reach (custom)
· Swing Away Tongue Jack (with wheel)
· Tail gate (custom), locking with security alarm
· Tires, mud/snow, off road, 3 each, 12.50" x 33" x 16", only used for one short trip
· Wheels, 3 each, 10” x 16”, alloy, bolt pattern fits Bronco and many Jeeps, extra spare tire if you
damage a vehicle tire on the trail.
AUXILARY COMPONENTS:
· Backup helper (tennis balls on magnetic base poles)
· Bottle, battery filler
· Canopy 10' x 10' (stand-alone pop up)
· Coffee pot, cooking pots, utensils
· Electrical extension cord, 50 feet
· Fire extinguisher
· Front jack extension, sometimes needed for rough ground.
· First Aid kit
· Generator, Honda, 1000-watt, charge trailer batteries, phone batteries etc. or run big amp accessories or tools.
· Heater, catalytic, propane, use only in well ventilated area.
· Heaters, 12 volt, 2 each, small
· Holders, paper plates, paper bowls, trash bags (inside storage compartment)
· Lights, solar, camp marking (find trailer on a dark night)
· Lantern, 12 volt
· Outdoor carpet 12' x 12' (lay down behind trailer, keeps the trailer cabin cleaner).
· Solar Panel, 45 watt, charge main batteries, phones, etc., run radio or accessories.
· Stands, hold up front window rock guard for storage shelf.
· Stove, 2 burner, propane, extra propane bottles
· Tables (aluminum), camp, 2 each
· Water containers, 5 gallon, collapsible, 2 each
· Wheel chocks
· Battery Monitor.
MAJOR COMPONENTS:
· Battery meter
· Fill/drain kit
ELECTRICAL SYSTEM:
· Fire extinguisher
· First Aid kit
· Lantern, 12 volt
· Wheel chocks
