OEM Denso AC condensation drain
Utah
My AC unit has drain nipples on both sides, however only one side is hooked up, the other is making a puddle on the floor. Did the factory cap off one side, or have hoses going to both? This vehicle is RHD if that matters.
I would put a "T" in the drain line and connect it up to the other drain with a 90* fitting. Taking care to have that new drain line to slope down to the "T" at least a little.
Yes it’s just a T piece to connect the both sides in to one hose. I can grab a photo for you as I have a couple here. I’ll just have to find it as I’ve been moving garages and all my parts are in unlabelled boxes, so I hope you’re not in a rush!
A picture would be great. The diagram really just shows there is a T. Definitely not enough bends shown in the diagram.
I wonder if someone messed with mine, I have one line draining through the floor, and one through the firewall, all with a Y fitting. Maybe someone drilled a hole in the floor, or is this oem? It's a 1981.
Thanks for the responses so far!
Very nice, thank you! I'll have to figure out a solution where the hose is clamped down to the unit with a screw
