Nuts and Bolts (6 Viewers)
That was quick - 31lbs of fasteners just arrived!!
62612 6x12 bolt
62616 6x16 bolt
62620 6x20 bolt
62820 8x20 bolt
62825 8x25 bolt
62830 8x30 bolt
62835 8x35 bolt
31706 M6 nut
31708 M12 nut
03796 M6 nut w/ captive washer
44106 M6 lock washer
44108 M8 lock washer
40706 M6 flat washer
40708 M8 flat washer
I ordered 100 each of the bolts and then the corresponding number of nuts/washers/lock washers for each
I am waiting for the final quote with shipping and will update shortly.
Thanks for the heads-up on the M10 - and no, I never heard anything back from Kevin either.
For almost 3500 pieces - $654 + tax
The yellow zinc coating is much more uniform than the pictures imply.
The fasteners appear to be 1st rate.
:bounce::bounce2:
Time to start bolting things together.....
3500 pieces? Did you order a whole lot extra? Your list only totals 1400... ;):D
Those do look good, but $654 Ouch! I do like the SEMS and indented heads though.
For my engine and frame I have just been de-rusting my OEM bolts and powder coating them. I can replace them later when I get the money to buy good ones. For the body bolts I guess I will order from Wurth...
:cheers:
:cheers:
100 each of the 4 types of M6 bolts and M8 bolts and 400 each of M6 nuts, M6 flat washers, M6 lock washers, M8 nuts, M8 flat washers, M8 lock washers
"Those do look good, but $654 Ouch! " - don't ask how much the quote from Toyota for the same parts was... :rolleyes:
:doh: Ah come on, I need sticker shock! How much was the Toyota quote and who did you get to give it too you? :D
For 1690 pieces......drum roll.........
$1192.85 + tax :)
Stevinson Toyota in Denver
The Wurth line is a good lead. They have an excellent selection of hardware. I notice that they do a kit (p/n 19641274) of metric flange bolts and nuts that covers most of the common sizes although it's not yellow plated.
Funny, I was just creating a small new entry for this thread when it popped up!
Front Brake Hard line bracket to frame bolt
1 8mm x 1.25 x 20mm. Split and Flat washer. 12mm head but 13mm fits
Hi Guys, I think the problem with Kevin is that it was really a PIA to get the bolts he did for me and I guess he has other fish frying? He still has never sent me a bill and we do a good bit of business with him. He has billed me for plenty of other stuff since then. I could call him about the JIS stuff, but I suspect I would get the same answer you guys have gotten, "I will get back to you". I guess I was lucky to get what I did?
PS. Thanks Coolerman for all the hard work you have done to keep that spread sheet current.
I ordered the p/n 19641274 set of bolts from Wurth. Pretty nice, comes in a steel box, bolts are 10.9 grade. Ordered a bunch of other bolts too, arrived quickly, very nicely packaged and presented. The pricing is hard to gauge as it decreases the more you buy, shipping is $5 flat if you spend over $300. I also got the least expensive item for free as a first order. I might save up for a bunch of SEMS bolts.
Updated Wurth Contact info:
E-Mail: info@wurthusa.com
Or call us toll free @ 1-800-WURTH-USA (1-800-987-8487)
Address:
WURTH USA Inc.
93 Grant Street
Ramsey, NJ 07446
Phone: +1 201 825 2710
Fax: +1 201 825 3706
I'm not sure if this has been mentioned or not already, what size is the tie rod and relay rod clamp hardware and is the nut a special type friction nut?
Courtesy of TMACK
Lower Thermostat Hex Plugs
Note: For later model housings to fill holes for sensors.
2 16m x1.5m HEX HEAD PLUG with rubber O-ring
Link to company : 4030M-16x1.5 METRIC HEX HEAD PLUG
Originally Posted by Coolerman
Been awhile...
Steering Wheel to Column Nut
1 12mm x 1.25 thread nut. Note: Column Shaft only has 15mm of thread so needs a thin nut.
I just cant make this work...bought 2 nuts from 2 different stores 12 x 1.25....any other possibility for a '65?
Okay - My steering wheel to column (36 spline) is a 12 x 1.50.
Was the reference for a 12 x 1.25 nut from a later 33 spline perhaps?
Coolerman
On my 79 2f... Timing cover has only 5 of the short split washer bolts. They all have a Phillips head in them and they are 6 x 8 with a pitch of 1. They all have the split washer... the other three... are longer and go on the left/passenger side of the cover. They go through the backing plate and have a nut on the back that is supposed to hold 2 brackets on the back. One bracket has 2 holes on it... and the other one has one... I still can't find the one hole bracket as my wire wheel flung it someplace in my shop and I am still looking for it... going on 4 months now. :eek:
Anyway I will take measurments of the other 3 bolt lengths and get that info to you here.
