Now this looks Sweet!
Discussion in 'FJ55 Iron Pig Preservation Society' started by MiniPigg, Nov 6, 2005.
  1. MiniPigg
    MiniPigg
    1,923
    Media:
    21
    Albums:
    6
    2
    Jan 2, 2005
    CouleeDamWA, BoiseID
  2. Yotahilux
    Yotahilux
    196
    Apr 29, 2005
    VA
    That would be sweet
  3. RUSH55
    RUSH55
    1,752
    515
    Oct 18, 2002
    Cottonwood, Az.
    Yeah, I think you're gonna start seeing more of this - which is a good thing. I'll wait until something similar becomes obtainable and real world useable before I pull the 2F.
  4. MiniPigg
    MiniPigg
    1,923
    Media:
    21
    Albums:
    6
    2
    Jan 2, 2005
    Heck... I think it would work if you used a VWAG 1.2TDI running just above idle to keep the batteries charged for the electric motor....... normally the Audi A2 with the 1.2TDI gets about 80mpg. Ofcourse there are other 2cylinder diesels that are used for the main purpose of generators.
  5. MiniPigg
    MiniPigg
    1,923
    Media:
    21
    Albums:
    6
    2
    Jan 2, 2005
    Have been kicking this around for sometime now. I am going to post it with this thread rather then starting a new one. Here is the basic information:
    FJ55 Specs:
    Wheelbase 106.3 inches
    F/R Track 55.3 inches
    Windth 68.3 inches
    Length 184 inches
    Height 73.4 inches
    Weight 4100 lbs
    1976 4.2 2F engine
    135hp@3600rpm
    200ft-lbs@2000rpm
    VW 1.9TDI engine
    90hp@3750
    150ft-lbs@1900
    2002 Jetta TDI
    3020 pounds
    Im just going to rehash some of the info I posted earlier today:
    Not all that sure but I think an FJ55 is about 4100lbs stock. If the 2F is 700 lbs, then the FJ55 minus the 2F is about 3400lbs. A turnkey 1.9TDI engine is just under 300 lbs. Placing it into the 55 would bring the weight to about 3700lbs.
    1.9TDI's are rated at 90hp/150ft-lbs at the wheels. Everyone I know that has brought their VW's to get a baseline dyno is almost at 89/90hp and 148/151ft-lbs. So with a decent 20% drivetrain loss that would mean the power at the crank would be about 108hp/180ft-lbs. With an Upsolute chip you are looking at a good 33% linear gain in horsepower and torque. So at the crank its about 143hp/239ft-lbs. Add nozzles and injections its another 30% increase making it about 185-190hp and 310-320ft-lbs reliable power at the crank.
    The VW 1.9TDI powerband is very similar to the 2F so I figure gearing is about the same. Plus it revs up like a gasoline engine. Our 2002 Jetta 1.9TDI fully loaded with an automatic transmission weighed in at around 3000lbs.
    I think the VW 1.9TDI would work in a pig. Including after all the mods. Even after the mods the engine remains very reliable and maintains good longivity. The noise is very low. Most people do not even know its a diesel engine. I think this engine would be perfect in a 40 series.
  6. ridgerunner
    ridgerunner
    1,192
    4
    Dec 7, 2004
    Wyoming or Antarctica or....
    My 55 may not be too far from stock, but I would be it weighs damn near 6K when I load it up to take it down the road....
    Personally, I want a bigger cummins. ;)
  7. MiniPigg
    MiniPigg
    1,923
    Media:
    21
    Albums:
    6
    2
    Jan 2, 2005
    When we had our last pig weighed it was around 4200lbs.
