MrTorgue
Grizzly Clint
Saw that thread a long time ago. Any one find a pic of the 2010-2013 seat fan? I'm coming up empty. That's the one that is the worst.
That thing is tiny. No wonder it's terrible. I need to get a hold of one so I can disassemble it for research. Perhaps I could find a way to scan the housing and 3D print a chassis that uses the same mount points that would allow either four small or one large high flow Noctua PC case fan.10-13 seat fan
2010-2013 Lexus GX460 Front Driver Seat Blower Motor 85860-60020 2010-2013 OEM | eBay
Find many great new & used options and get the best deals for 2010-2013 Lexus GX460 Front Driver Seat Blower Motor 85860-60020 2010-2013 OEM at the best online prices at eBay! Free shipping for many products!www.ebay.com
That's how my RAM 2500 is. It's night and day.A couple years ago I did a track day driving a new Porsche Cayman. Aside from all the fun, it was getting a little warm so the tech (in the passengers seat showed me the seat coolers.
Oh my gosh! It was pushing so many CFM's I though I was a puck on an air hockey table!
THAT's how I believe our seats should be.
So when the HVAC is off does the fans just use their own air then? When I'm alone I run with the HVAC off and windows down a bit unless it's 80+ degrees outside.IIRC... some use Peltier coolers, direct plumbing of AC fans to seats, and I think even some AC setup like the console refrig in the LC and non-US market 460s
I just printed it in draft
I had to resize example here to get this print to fit.
I probably won't know for a couple months if I notice a difference since weather is still cool and rainy here. I've actually not really had any complaints with seats in mine but climate is far milder from heat perspective than many of you.
Under Drivers seat:
Or with foam collapse or being depressed for years. I'm sure mine isn't in that good of shape given it's a 2010 model.I think it very well could as well as how much debris has found it's way down into the seat.
I am green with envy. Here is the temperature pattern in Houston:So when the HVAC is off does the fans just use their own air then? When I'm alone I run with the HVAC off and windows down a bit unless it's 80+ degrees outside.
Looks like a scoop may be worth a try. I'm interested in seeing the foam channels, as was mentioned.
