Does anyone by chance know where I can get a replacement ECU for my 96 fzj80? What I initally thought to be a fuel relay or fuel pump problem, I'm now positive is a bad ECU.
It all started with the engine turning over but not starting a few times in the last month or so. I figured it was cruddy gas and put in some seafoam. I tried it a few times and it finally started, and it ran for a few days. Now, it's been over 3 weeks of tinkering and investigating and it still won't start.
Using the FSM repair manual and the FSM wiring diagram manual, I've tested & retested the following items and have eliminated them from suspicion:
EFI main relay, IG Switch, fusible links, Circuit opening relay, fuel pump relay, fuel pump (actually bought one), fuel pump resistor, and the park/neutral switch. I've also check the voltage and resistance of the wiring between the above items. I've also checked the voltage at FPR, FC, STA, etc on the ECU and all is good. I checked the grounding at the fuel pump too - all good.
Why do I think it's the ECU? When turning the key (CEL does come on) and trying to start the motor, I found that the Circuit opening relay was not engaging. After swapping the relay and testing the wiring back to FC at the ECU, I found voltage all the way there. But in looking at the wiring diagram, FC is part of a transistor circuit; without voltage coming into the "back" of the transistor, the circuit opening relay can not reach gound at FC (again on the ECU). Same goes for the fuel pump relay.
By shorting out the circuit opening relay to ground, I can get it to engage, but the fuel pump still does not come on. When shorted, there is voltage at FPR on the ECU, but again - there is a transistor here needing voltage in the "back" to allow FPR to reach ground. Both of these transistors (Tr1 and Tr2) are looking for this "back" voltage from STA at the ECU and at NE. I can test STA by cranking the engine over and there is current. I tested the crankshaft position sensor and it had the correct resistance. I could not perform a "cranking" test as I don't have an oscilloscope. Lastly, to eliminate a grounding issue question with the ECU, I did a continuity test of the E01 ground and it was good from the back of the ECU to the upper intake manifold. So in summary - unless I've missed something (and all input is appreciated), I'm positive I need an ECU.
Anyone got a spare to sell?
Thanks,
Dan
and for the E01, E02, and E03 terminals of the ECU
Thanks,
Dan
