So I swapped the cap, rotor and plug wires, same. I guess next up is to buy new gaskets, unless someone has another idea?
So to be clear, with the Weber 32/36 is ran once warmed up okay with a bad flat spot but drove down the highway, roads okay. I put on the new TH carb and it idles terrible, smells of gas and when I hit the accelerator large clouds of black smoke comes out. Can't even back it in the driveway. I have sprayed carb cleaner all over the place and there is no difference but it is also idling terribly.
Also here is a couple pics off of the header to the manifold, what are these for? Needed?? Also EGR internals are removed, Should I still have this hose connection to the canister? Could this be my intake air leakage?
Any recommendations on the gasket, vendor, and also should I just plan on buying two to double up?
Give me a buzz. It's possible the idle solenoid or passage is plugged. Also could be a vac leak. Have you tried spraying carb cleaner around the manifold area and see if you get in change in speed?
Any shaft wobble in the dizzy? Timing set at around 10 degrees BTDC?
8644140563
Marshall, no wobble in the shaft of the dizzy, it cleaned up well. Spins freely, the only thing I "may" question is the signal generator. Its there a way to test it?
For the carb, the solenoid does not stall the engine when I disconnect it, no change at all. If I close, turn all the way in, the idle mixture no change. I have a feeling it is clogged, how could I confirm this?
