Please note, this is all new for me, I have never worked on a carb for a vehicle. I can figure stuff out but this is not something I have done now have I ever had a vehicle like the FJ.
As you will see in my last posting I am having a H--- of a time getting this 2F running. . . . . . . . . . . . . . . . . . . . right or just running smooth. I spent a small fortune at a local hotrod shop and they could not get it right, I ended up learning how to adjust a carb, timing, needle adjustments and got it running better but not great.
So I decided to buy a Trollhole carb since that kept coming up as the be all answer.
Truck arrived to me with a Weber 32/36 from Lilopad. It ran fine when we got it and then I fueled it with 93 Octane, that is when we noticed it did not want to run one morning. That is when it went to the shop above for 3-4 weeks. With the 32/36, it would run but there is a really bad sputter in-between the low and high, when cold it did not want to drive at all unless you floored it. Then when you shut it off it would burn off the extra fuel sometimes for about 2-5 seconds. Timing was set where the BB was just before the line, it seemed to be best there. So it ran but really rich. I followed a very good step by step on setting the Weber and it got things better but still had the sputter etc. Ideas adjustment on it did nothing though. Idle would go up with the timing but that was it.
So the Trollhole carb is installed and manual choke was re-installed, It starts and runs but runs very rough. It idles okay with the choke pulled out tot he first notch while in higher RPM but the engine is shaking . The exhaust is gas smelling and semi smokey. Once fully warmed up I can drop the choke and it is idling at about 650RPM but it is very rough, same gas smell and smoking.
I found the form: https://forum.ih8mud.com/threads/ru...e-carb-and-dizzy-install.768565/#post-8777572
I went through the steps listed. If I turned the Dizzy all the way counter clockwise it ran better but not smooth. still gas smelling and smokey. I sprayed around the base of the carb and nothing changed in idle.
I now pulled the cap of the Dizzy, checked TDC 7* BB and it looks right. When I did this I pulled the plugs all but one came out real easy, #3 threads look fine but is was a bear to get out. All 6 plugs are BLACK soot, assuming from previous carb.
I am at the point of giving up on this truck. We love the truck but just want it running right. I have had some great help and have read great posts but I really need some step by step help.
So I decided to buy a Trollhole carb since that kept coming up as the be all answer.Truck arrived to me with a Weber 32/36 from Lilopad. It ran fine when we got it and then I fueled it with 93 Octane, that is when we noticed it did not want to run one morning. That is when it went to the shop above for 3-4 weeks. With the 32/36, it would run but there is a really bad sputter in-between the low and high, when cold it did not want to drive at all unless you floored it. Then when you shut it off it would burn off the extra fuel sometimes for about 2-5 seconds. Timing was set where the BB was just before the line, it seemed to be best there. So it ran but really rich. I followed a very good step by step on setting the Weber and it got things better but still had the sputter etc. Ideas adjustment on it did nothing though. Idle would go up with the timing but that was it.
