New Trd Pro Replica wheels on 100 series fitment (2 Viewers)
Chattanooga, TN
Anyone see any issues with mounting these on a 100 series? From what I understand I’d need 1.25” spacers in order to run the wheel centers. However, are there any other issues I’d run into anyone can think of? These are similar to what a new pro tundra or sequoia come with, but in a 5x150 option.
Thanks for the help.
  • Size: 18x9
  • Offset: ET +18
  • PCD: 5x150
  • Center Bore: 110.2
  • Color: Matte Black
  • Weight: 30lb
  • Lug nuts: not included. OEM compatible14x1.5 mag seat
  • Load rating: 2,500 lbs
  • Certification: SAE J-2530, DOT approved
  • The center cap is interchangeable with OEM center cap
Very curious of your experience if you end up going this route. The AGP wheels seem to show up quite often but have never see actually running a set
  • Size: 18x9
  • Offset: ET +18
  • PCD: 5x150
  • Weight: 30lb
Well, you are correct. 1.25" spacers required to run the provided center cap and miss the grease cap. I suppose the other option would be to replace or flatten the grease cap. I was a willing guinea pig on this one. I think it looks pretty damn clean. This is with 33" tires and a modest 2" Old Man Emu lift.
I am in the process of exactly this, sort of. 2001 LX470 I just picked up, got these wheels and they did not clear the hub on the front wheels. I did not want to do spacers so we are grinding out just a little bit from the inside of the wheel to make it work. It's so strange that they added a lip on the inside of the wheel that makes this not fit. Back wheels fit fine no spacers, it's just the front. Should have it done in a couple days and will post pics. The wheels look great and I am excited to get them on the LX.
I really wanted the wheels off a heritage edition LC but they were around 1000 each. I paid 10k for my LX and it has 250k miles (thing is still mint and runs great) but I cant drop 4k on wheels for a 10k car just doesn't feel right lol.
I have a set of these wheels sitting in my garage. Did you have any luck with grinding the inside to clear the front drive flange?
