Thank you for the heads upWelcome! It's a good time to invest in a ball joint/front end service kit. I don't think I'd try and drill the ball joint out. You might botch up the tapered hole.
https://www.amazon.com/dp/B07F34PJF...&pd_rd_r=e4b55bec-19b0-11e9-a1d6-d7c18bc79752
Sweet! Haven’t got that far on the rear yet on the rear. I will look into it soon. Thanks a lot for the info.good project right off the bat! I want to get TC upper arms in the future and this is good homework for future truck work. Good link there @hoser
What are you going to lift the back with? The LX springs are the lowest load rated springs as the AHC helps buffer the difference once loaded. If you using stock bumper, the medium OME 860s will give you 2.5" lift and get the most of the the shocks you got/getting.
T-bar brackets to frame are TQ spec of I remember 160ft/lbs, so you may need to rent/borrow a higher spec TQ wrench.
Also those AHC rear Shock bolts on the rear are MAJOR freaking PITA! With the help from other mudder's info, I bit down and bought this low profile ratchet system. When under the truck, I don't think there would have been any other way. The nut is in a cone and there is only 2" above for access.
https://www.amazon.com/gp/product/B000NIAKJK/ref=ppx_yo_dt_b_asin_title_o00__o00_s00?ie=UTF8&psc=1
The longest flex head 12mm is for the two bolts for the AHC lines on the rear shocks. This was ample length.
https://www.amazon.com/gp/product/B01F512F7Y/ref=ppx_yo_dt_b_asin_title_o09__o00_s00?ie=UTF8&psc=1
So if I am going to eventually ditch the AHC I can unplug it in the engine bay and remove it?Height control sensor for the AHC. I don't know if you have a few extra brackets on the TC UCAs, mid-arm or so is where it would attach.
It was in perfect shape. I will do that. Thanks gents appreciate it!!!!!Since you are changing to conventional suspension, you should remove it, box it up and send to another member that needs it (not me).
Just bought both for the future. Thanks again.good project right off the bat! I want to get TC upper arms in the future and this is good homework for future truck work. Good link there @hoser
It is. The previous owner just had it re-clear coated. Did a decent job. At first I thought it was in a wreck but all the numbers match on all the panels.Is the paint on your LX that glossy in real life? Sure looks like it was well cared for.
