1911
chupacabra
what are the websites of the guys above!?
City Racer LLC
OEM Quality Parts & Accessories
Cruiser Outfitters
Bring that badass 40 we got room for ya!Not trying to hijack the thread, but I'm trying to convince my wife to move to Rapid City. Lived there when I was younger and love the area.
Most of your questions can be answered with a little research on this site and the WWW but here's what I know.
1. For Sale - 40, 50, 60, and 80 series FSM for a hell of a price. The manuals for around 1980 will probably be the most specific to your truck, although your truck seems to be a mix of many parts from different years. Oil and antifreeze amounts are actually in the owners manual, not the service manuals for some odd reason, Toyota did that on everything. Specter Off Road used to carry re-prints of most manuals. Oil is 8 quarts, give or take, that is what I have always put in. Antifreeze, use a 50/50 mix, takes about 4 gallons as I recall. The cooling system is full when the radiator is full to with about half the tube full of fluid when you take off the radiator cap.
2. That looks like a Vintage Air variant of an AC unit, the above suggestion of a Mohave Unit heater was good. You may be able to add the heat coil to that unit. Water pump does not change on engine, hot water is taken from the rear top of the head by the brake master via a nipple, will probably have to source one. There would be a cable actuated heat control valve on the firewall, I think City Racer has repros, and then the line enters the firewall more center of your current AC lines on a stock settup. Goes through heater and then comes out right next to the inlet line and travels to a nipple installed in a metal "Tee" fitting basically in the lower radiator hose. You probably have a one piece hose. Look up lower radiator hoses for an FJ40 and you will there are two parts with a metal piece in-between. This part can also be sourced pretty easily. You mentioned prior there was no thermostat, did you pull the top off the thermostat housing to find this? Use only a Toyota thermostat, they are the best, and get the gaskets that go with it. There is a paper gasket for the housing, and two rubber gaskets that the thermostat sits on and one goes on top. Without them and the proper clamping of the thermostat by the housing with the paper gasket the thermostat will bypass and not function properly.
3. They ride rough, period. You have lifted springs, probably makes it rougher, no idea if the shackles and bushings are swinging freely. Coil springs on newer jeeps ride softer, hence reason Toyota went to coil springs on the land cruiser after 1990. I would look into the steering box for issues, also look at the front axle knuckle bearings, center arm could be an issue too. Too much that could be wrong to diagnose easily.
4. Carpet kits for these have always been expensive due the cost to produce and the overall low quantity of actual trucks to put them in and consumer of said product. Carpet holds moisture and rusts the floors usually. They only ever had rubber matting after 75. If the truck is loud, carpet will only help a little. Factory used heavy tar sheeting on the floors under the rubber mats after 75. Anything less does not do much for sound, I have tried. Some of the new materials like DynaMat and such will help, the prior mentioned repro rubber mat is probably the best option. I seem to recall an Australian carpet years ago that was molded for the floor, expensive also.
5. Hardtops are nice. As others have pointed out, they add up in cost unless you can find a decent one used for a good price. They do come up from time to time for sale. Your truck was a soft-top from the factory. As others mentioned prior, the rear doors have some differences through the 25 year run of the 40 series. Specter had some good references on their website for the different doors. The late hardtop may be the logical choice, however, the pre 75, barndoor/liftgate top may be the best fit with your lower rear doors. The hinge bolt on spots are different on the rear tub if you use the ambulance doors. I don't know if the tops of your barn doors will fit with the upper liftgate. It looks like the proper doors could be fitted if the hinge locations are the same, they look to be. In some markets the upper liftgate continued while the full height ambulance doors were all that was offered in the USA after 1975. There are also two different bolt hole patterns on the hardtops for the top of the windshield frame, 2 vs 4 bolts this can be fixed, but is something to look at. Your windshield frame should have two threaded holes on the front face. The early windshield frames have 4, but the wipers are on the top. Early vs lat tops will differ the same. The front overhang of the fiberglass cap also changes slightly with the change in the wiper arrangement. The tops are multiple pieces though, and parts can be mixed and matched to work. It is unknown if you have all the threaded holes in the top of the tub to make one work too.
The soft top works very well actually, I'm running one now, for 3 seasons of the year they are fine. Not quite as tightly sealed as a new Jeep, but they work. I added some heat bubble wrap and jute to a custom sewn "pillow cover" if you will that sits on the bows under the top overhead. This helps block some sun heat, hold in cab heat and absorb ambient noise in the cab and reduce wind noise.
I would strongly advise you fit a rollbar and move the shoulder belts to it. There is no protection with that top arrangement. To keep the long rear seats you have now will require some mods to them, primarily moving them inboard, adding fold down legs to them is needed then to keep them from bending in use. Probably need to be a custom rollbar, although the later stock bars can be added, but they are not very strong. There used to be one from Confer, don't know if anybody still has any old stock of those bars. Specter has some choices too. I opted for a full cage from Redline, came out nice, I had to weld up the kit myself.
Nice looking truck, but definitely post more pictures to help further answer some of your questions.
I notice you said it was refurbished, but were needing to replace some things. Was this purchased from one of the South American restoration companies that ships to the states or a privately brokered deal? I ask because I also have 2 fj43s from South America.
Neither had a thermostat, and both seemingly ran ok when first imported but now have issues after adding coolant. No heaters in mine either. Looks like a solid paint job and body! Be prepared to run into some potential issues with repairs. South American cruisers are pieces together really with whatever is handy to keep them in use. At first glance things under the hood may look normal, but they may be slightly off and call for some modifications.
Matt,
What fitting are you talking about? The only variants on the water pumps is if the block has the oil cooler or not, that dictates the extra fitting on the water pump and thermostat housing. Heat is off rear of head (hottest water in block) to the core and back to lower radiator hose.
