- Thread starter
- #21
Got her on the lift today for:
Oil Change - AMSOIL signature series 15W-40 Synthetic Diesel Oil - filter (90915-30002), plug (90341-18021) <- thanks OGBeno, and gasket (90430-12031)
The newer 10mm allen bolts work great.
Transmission Oil change - (The severe gear instantly made the shifting smoother. It obviously needed the new forbidden jelly.)
Amsoil 75W-90, fill & drain plug (90341-18021), and gaskets (90430-18008 x2)
Transfer Case oil change -
New air filter - (17801-61930)
Greased Axel with Valvoline Lithium Grease - I noticed when I added grease to the Slide Yokes, the center section slid back, is this normal? I believe it was the cover moving. I could see grease coming out of the spiders just fine, but dont have experience on Slide Yokes.
Not every day you get a good look underneath, it had some coating applied at some point and overall it looked really good (at least from my eyes)
To do list:
Grease gun with Valvoline Moly Grease for Steering Knuckles
Front & Rear diff oil change - Amsoil 75W-90, fill & drain plug (90341-18021), and gaskets (12157-10010 x2)
Side Panel restorations
Automatic door locks
Clean and restore doors and window rollers
Someone also moved the speakers to the door, so I'll need to clean that up.
Happy Friday!
To do list:
Happy Friday!
