New Head vs Rebuilt (and More)... (7 Viewers)
jaymar
SoCal
So, seems the head gasket is blown as I have a misfire, and gas in the radiator. Questions...
1) What is the approximate cost of machining/rebuilding the original head with Toyota parts vs buying a new, complete head? I'm in Los Angeles, if that matters.
2) What are the highest-quality/most reliable/most durable head components to use if NOT using Toyota parts?
3) Assuming the bottom end is in the kind of shape most of these seem to be in at ~240k (pretty damned good, that is)--to what extent can I expect a new/rebuilt head to "refresh" engine performance and reliability? In other words--again assuming a lower end in good shape--how does comprehensive head work compare with a full rebuild? And how might the old lower end degrade the fresh head?
4) What else should I be looking at / doing / replacing with the head off?
Thanks for any help!
I don’t have hands on experience with a 1fz head in particular, but I have with other engines. In my opinion a rebuilt head from a quality automotive machine shop will come out with a higher build quality and tighter tolerances than a off the shelf factory replacement. And it will probably be cheaper.
I would go for a rebuild rather than replace, unless they find cracks or it is so warped that it is not salvageable. But I don’t think that is very likely.
I'm going thru this now.
Original head was too warped (by oe tolerance) to skim down. Shopped a bit for used heads, got lazy and bought new from dealer.
The rebuild with old head was quoted approx 3k- inclusive of a ~500 machining fee
Add new head cost 1500
If I had room and time, I'd def diy to save a lot on the labor cost...
Is that new head complete at $1500?
No, bare head is approx $1400
Ah, thought that sounded way too good. Guess that pretty much decides that. Has anyone priced the other components lately--everything you'd need to install on a rebuilt head?
Depends if you use OEM or aftermarket. check any of the online sources for springs, Intake, Exhaust valves, etc. I forget what I paid, few hundred for new OEM valves, couple hundred more for springs??
One forum member got burned when he installed aftermarket valves (US brand name but made in Chynna??) that were too soft, had to pull it back apart after a year or so IIRC. You gets what you pay for.
Oh I'll go OEM if I can swing it. Anything you'd reuse, or just replace it all?
I’d take it to a shop first man. Good chance all you need is some machine work and a top end tune up.
Or go load the parts cannon, whatever you want to do.
I want it to be good for another 300k, is what I want… 🤠
where'd you find one for 1900? I was looking at the parts.toyota.com earlier and it was around 4.5k
A new 1FZFE head (11101-69107) retails for close to $2000, smart shopper price $1500+/-. A new 1FZFE short block (11400-66041) retails for ~$4500, discounted price ~$3500+ depending on the discount, if any, that you can find.
All above refering to US sources (examples below):
I had my head tested and completely rebuilt, flattened, etc by a very reputable shop using oem or better components for $800 and I’d trust it as much as a new oem any day. I vote rebuild.
I’m in this boat now. I’m fortunate that I’ve got a 80k mile head off an LX that lost the oil cooler and got a nasty knock. I think I’m just going to run that.
I'm finishing this job right now, and, although I haven't added up the receipts, and I'm doing all but the machine work myself, I think the total is around $1500. That includes (approximately) $450 for the gasket set, $500 for the machine work and the remainder in other parts. I did not need any new head parts, but I did need 6 new head bolts.
There are many threads on this job, but, FWIW:
1) I didn't pull the engine. I won't do that again. It saves no time and once out, you can access all the engine/transmission/transfer/engine bay/undercarriage to clean/update/etc, while you're waiting for the head to return. You're also taking a really big chance that your bores are cylindrical. If they're not, once the head's out, there is very little practical way to pull the engine.
2) Plan on breaking some, or all, of the sensors, connectors, or both, on the intake side of the head/engine. You may not, but I lost 50% of them due to age-related material failure. Everything I broke is still available. Ballenger has the OEM Sumitomo connectors, with the terminals, which you have to figure out and order separately from Toyota. Unless you really want to rewire the connector housings (I am, but that's just me), I'd recommend the pigtails - much easier to install.
3) I took the time to replace the brushes in the alternator and starter (I actually rebuilt both). Full rebuild kits are available from Alternator and Starter Parts Wholesale (I highly recommend them). Toyota only lists limited parts for both. You can rebuild them yourself, or just replace the brushes, for a fraction of the cost of replacement. Now is the time, while they're out, or accessible.
I would also replace the JIS cross head screws (all 4) on the starter housing with socket head cap screws. You'll understand why once you try to remove them. They are glued in, and, although the installation torque is low, the heads are ridiculously soft and will strip out. I've repaired several, and stripped the screws on every one. They will come out with an EZ-Out. Replacements are not available from Toyota, since they are not considered a wear item.
4) Suspension components, at least shocks and swaybar bushings, are easiest to access while the head/engine is out. If you replace the shocks, plan to replace the swaybar bushings, because you can't access them unless the shocks are out.
5) I failed to do this, but the engine shop has the facilities to thoroughly clean the intakes and throttle body. If you decide to do it yourself, buy some Carbon-Off to remove the crud from inside all three (Brakleen will remove it, but it's ridiculously expensive for the whole set). I spent two weeks trying to clean mine with at least a dozen chemicals and abrasives; none worked on the interiors to completely remove the burned in carbon. My bead blast media wouldn't even remove some of the baked in stuff. It did polish the exterior really well, though.
I would not recommend assembling the intakes and throttle body unless they are as clean as the interior of the head. This is the only time you can safely get all that crud out and if Toyota wanted it in there, they'd have shipped the new engines with it lining the intakes.
6) I replaced every coolant hose and vacuum line. They all needed to be replaced. Many recommend Napa-type vacuum lines, but they are not metric sized and do not fit closely on the vacuum nipples. Toyota still sells vacuum lines, 90999-92008 (I bought 2-m). I also replaced my heater valve, because it was leaking; check yours before you throw money at it. This is one of the few engine bay items that can be replaced with everything else installed.
7) I blasted my exhaust headers and coated them with VHT primer/paint/clearcoat. We'll see how long it lasts. My next set will be Cerakote finished. I also applied VHT clearcoat to all the steel and aluminum parts I cleaned. Just to make them easier to clean later, and because I had it left over.
8) Now is the time to electrically check all the intake/throttle body-mounted sensors. If you don't know how to use the DMM, you will by the time you're done (Toyota training is in the Resources section).
9) Finally, don't forget new plugs and oil/oil filter. I replaced the OEM fuel filter a couple of years ago, so it's going back in. If you haven't replaced yours, now is the time.
Again, many other threads here on oil cooler, oil pump, power steering pump, cooling lines, removal of a) EGR, b) PHH, etc. I didn't touch any of that, because I didn't have the need. You may.
HTH
‘Better than OEM…?’
HTH
Valuable info, thanks for sharing. Did the knock sensors break when you took apart the intake?
I see the partsouq Toyota HG set is like $200, but they’re out. There is a ‘Teikin’ set for $56. That makes me a bit wary. Anyone used them?
I wouldn't risk it myself if I'm already going to the trouble of taking everything apart.
AFAIK, you can get the OEM gasket kit through any Toyota dealer.
