After years of searching I'm finally the proud owner of a 1994 Landcruiser. Thank you to the many people on this forum, and to the people at Slee, for the invaluable research, information and advice. I was able to make an informed decision with your help. You are appreciated.
1994 FJ80 w/ Lockers
184,000 miles
Clean CarFax, entire life spent in Texas.
Engine runs great, no drips or leaks. Air blows incredibly cold. Axle code is 294 and lockers engage. Frame is absent of major collision artifacts. Doors are all original, power windows and seats work.
Needs:
- New front seat bottoms. Passenger ripped, Driver close to ripping.
- Steering wheel shroud
- Dashboard is cracked in two places
- Windshield is pitted and cracked
None of the above should be shocking. I'm looking into replacing the shroud myself. The seats are a must. Covers are not an option so I'm looking into getting them reupholstered. I'd really like to replace the dashboard but I'm not sure what part it is (part #1 on this diagram?). A cover is significantly cheaper and I've heard of dash tape that you can use. The cracks are 1/8" and run perpendicular to the dash in two nice straight lines.
First stop will be the local dealership for a service inspection. I'm going to have someone go over the entire thing. I know it has had an oil change recently but I'm not sure about anything else. What would you recommend for a service baseline? I'd like to drive this thing for quite some time and really want a good understanding of where it's at.
Thank you for your time and wisdom!
184,000 miles
Needs:
