- Thread starter
- #61
I guess I like stirring S%^# up! Very glad to be part of this group. Probably the most helpful auto group I've EVER been a part of.
Indeed!@Izzyandsue should be listened to pertaining to wheel studs. He knows a guy who knows a guy who once needed a lawyer because of them!
Testing with a manual proportioning valve instead of the LSPV has already been done by others. The conclusion was that the manual proportioning valve fully open or 50/50 front rear bias produced the best braking. I will agree that without ABS, some type of proportioning valve is necessary to tame the rear brakes and prevent the rear of the Cruiser from swinging around in an emergency situation.The LSVP is a proportioning valve. It determines the split of brake bias, front to back. The LSVP adds more bias to the rear as weight is added to the rear of the truck.
OPINION if you remove the LSPV you should replace it with an aftermarket unit, generally at the master cylinder. If you have no proportioning valve you bias will most likely not be to the front as it should be. You install the valve, test your brakes in a parking lot etc and adjust it until it feels right. Lock the valve down and forget about it until you feel you need to adjust.
Personally, I would not run a 50/50 brake set up, that is assuming that 50/50 is what you get with no valve at all.
TokyoToyota Drift
Nah you can get one to slide pretty easy, I've done it. It just takes a lot of stupidity (something I have a ready supply of), speed, and a wet surface.Is that how they got that LC in the new Terminator to slide like that? Lol
So far so good. But what do you do when one bolt just won't break loose.
Check the front caliper bolts after you've put some miles on them. They have a tendency to back themselves out from heat cycling and jam the caliper into the wheel.The torch and my PVC pipe breaker bar did the trick. So, happy to say, 4 new calipers, 4 new rotors and pads, and this project is complete. I'll have to start looking for brake lines. I noticed some cracking in them. But I just need to be able to drive into work tomorrow. My boss probably hates me... or forgot who I am.
Sorry for the 4 page thread guys! But I truly appreciate everyone who posted to help me out. It was a daunting task for someone who is a YouTube mechanic.
Forbidden coffeeThis is what came out when I bled the brake fluid. Never seen it so dark. View attachment 2174839
Got to hydrate more often!This is what came out when I bled the brake fluid. Never seen it so dark. View attachment 2174839
