I bought my first home in November. 2 bedroom house, 1073 square feet and has an 18x24 shop. All the wiring in the house was redone in 2003 and the garage was not done and does not have electrical service to it. Now that I'm all settled in, I need to wire up my garage and I don't know where to start. My house has 100amp service. Currently, there are two 30amp breakers joined for the dryer, 4 20 amp breakers for lights and receptacles, and 4 15 amp breakers for lights and receptacles. There are no major electrical appliances in the house except for the 240v dryer.
In the garage, I need 240v service for my MillerMatic 180 welder and the sticker on it shows a draw of 19.5 amp. Eventually I will have an electric oven so that I can powdercoat small parts, though it would be rarely used and I don't think I would need to run the oven the while welding at the same time. I will put in flourescent lights overhead. I need wiring for an electric garage door opener. I would like about 8 receptacles in the garage. It's just me living here, so it's not like I would be running two grinders at the same time on those receptacles or anything like that. I might eventually have a fridge/freezer in there. I will eventually get an air compressor, undecided if 120v or 240v.
Can I put a breaker in my 100amp breaker box and run wiring underground to my shop and put in a subpanel out there? Do I need seperate service to my shop? What size wire should I run underground? There is 30 feet between the house and shop, and about 8 feet inside the house to the box. I figure I will need about 65 feet of wire between each breaker box. I really don't know where to start, and what will be the most economical way to do this while still wiring it the proper and safe way. Can somebody give me some pointers?
