I’m removing the Weber and replacing it with a remanufactured carb for this FJ. Found out why the Weber would only run with the choke closed. First, the PO only finger tightened the bolts. Second, the adaptor plates are warped. Gee, no air leaks there.
Without having an original carb to work from, have several questions. Also, manufacturer had post 08/76 and pre 08/76 carbs. Not knowing when this FJ was built, went with the post 08/76 carb. Did I screw up?
1st - this hose comes from one of the adapter plates for the Weber and runs to the brake booster. Where should this hose be mounted?
2nd - Where should the solenoid wire attach? I located a green plug and was wondering if that’s where.
Here’s a photo of the green plug. Also, what are the solenoids shown in the photo? Any idea as to what the brown plug is? Heat gauge does not appear to be working.
3rd - Where does this plug into? The large tube showing to the right - where does it go? I just picked up a stock air filter for this FJ.
4th - Any idea as to what the black capped tubes are for? Large one appears to be associated with the fuel inlet housing.
And lastly, where can I buy a mounting plate for the carb to manifold? Appears I need at least ½” thick plate for everything to clear the manifold.
Thank you!
Thank you!
