Good post Drew
Preload is the key - set it up right and it will last. The only thing I do differently is the torque on the outer nut. I use an impact putting me in the 70lb range with loctite.
Large tires at high speeds are hard on wheel bearings and I have the outer nut come loose before. The ending preload is the same about 10lbs.
I'm not recomending this just sharing ones experiance.
Phil
Phil
