Good post Drew
Preload is the key - set it up right and it will last. The only thing I do differently is the torque on the outer nut. I use an impact putting me in the 70lb range with loctite.
Large tires at high speeds are hard on wheel bearings and I have the outer nut come loose before. The ending preload is the same about 10lbs.
I'm not recomending this just sharing ones experiance.
Phil
Large tires at high speeds are hard on wheel bearings and I have the outer nut come loose before. The ending preload is the same about 10lbs.I'm not recomending this just sharing ones experiance.
Phil
