Are any of you guys running a steering bump tube with an o ring on the pump side of the hose attached in the photo are something similar?
I ask because I started my cruiser for the first time for a while and noticed that the power steering fluid was leaking out. Originally I thought it was the hose where the fitting was crimped onto the soft line.Are any of you guys running a steering bump tube with an o ring on the pump side of the hose attached in the photo are something similar?
Do you have an actual link to the ad?
Honestly I’m not sure exactly where it’s leaking. I was filming the engine running and happened to check to make sure the power steering belt was running and noticed it was leaking.Idk, never used one. I've never had a problem with the h/p hose flared end. Is it leaking at the inverted flare or behind the fitting and the pump? There might be an O ring on the back side of the inverted fitting. If you use the fitting you referenced you'll have to change the fitting on the end of your hose to female.
Thanks! I can’t remember if my dad had the pump already or if I had bought it. Either way it’s been awhile so not sure.I believe there are two styles of pumps just like two styles of boxes. O-ring or flare connections. I assume you verified that the pump you have is for a flared pressure hose and not an oring hose? (From the pic I can't see inside the connection on the back of the pump.)
I don’t believe so but will have to look.Its hard tell, but it looks good. I think theres an O ring behind that fitting. Is there any imperfections on the hose fitting.
So I stopped at the shop that was closed on Friday and they believe it was not crimped properly. Also the hose is hydraulic and not a power steering hose.I think the inverted flare fitting on the pump unscrews and there is an O ring that could be leaking or the h/p line fitting was not tight causing a leak.
I listed a part number on herr somewhere for a jeep pressure hose. It is sitting in the shop now. Same one I used on the Mule build. Lemme dig it up.If you guys could post some pictures of your hoses that would be great. My steering box is a cardone 27-6529.
Here ya goIf you guys could post some pictures of your hoses that would be great. My steering box is a cardone 27-6529.
Thanks brother!Here ya go
Post in thread 'The Mule.' The Mule. - https://forum.ih8mud.com/threads/the-mule.171155/post-4509761
