My Saginaw Power Steering Swap
I also need to double check that it’s not leaking at the pump. In the video it was hard to tell because I didn’t have good footage of where the fitting goes into the pump. However you could see it pouring out where it was crimped to the soft line.
I also continued letting the motor run just to make sure the temp sensor worked and then thought to myself to turn it off because I didn’t want to burn the pump out.
I’m assuming that the one on the left is the pressure line.
Thats great news. Its strange, Rockauto's description of that box is different than cardones and cardones description doesn't seem correct either. I'm glad it worked out.
So as embarrassing as it is there might be a possibility that I had the return line and pressure line mixed up. I will send pictures soon to determine.
Dude - who are you? My wife? It isn't so much she doesn't listen but she says I mumble.
Interesting.
That is a J20 box - supposedly. That is what I have run with that jeep hose I listed. May be a dumb question - are you sure you are sticking the hose in the pressure and not the return?
:lol:
@pb4ugo or @Hugh Heifer did you guys also purchase the return line for the same vehicle?
I don't think so. I will have to see what that was. It was just a short elbow and then I ran fuel hose to a cooler and then fuel hose to the return side of the pump.
I just use a section on 3/8 metal fuel line, bent to my liking, then 3/8 rubber hose and clamps.
I ask because I started my cruiser for the first time for a while and noticed that the power steering fluid was leaking out. Originally I thought it was the hose where the fitting was crimped onto the soft line.
I went to the shop where I had the hose made and showed a video to the individual behind the counter and he believes I need the bump tube because it’s not getting a good seal because of the fitting is flared.
Attached is a photo of my pump and hose.
Interested in more details/photos of the bracket you used to secure the 2 bolts on the outside of the pump. It seems you used the dworry flat bar to secure two bolts to the pump. How is it attached down below?
I think my pump would feel more secure if I secured it at 3 points
I’ll try to get some photos in the next couple of days for you. If you don’t hear back from me hit me up again.
