All right fellas, now that I have a FZJ80 in my possession. I have decided to start a thread showing my attempt to bring this beast back to life. Unfortunately with having a LX470 to keep maintenance up on, and expensive taste in guitar's, I can't just dive in balls deep so I'm going to have to take baby steps. With that being said here is the order in which I want to tackle things to get her up and running. I will post pics as I make progress. In the meantime, if anyone has any advice or opinions to offer to help out, I'm all ears.
P.S. If you own a white/khaki colored 80 series L.C with a "Arizona Historic Plate." Thanks for passing the bug to me early last April in Sedona, AZ
Here is my to do list:
- New hood struts so the hood will stay open
- Clean up and degrease the engine bay
- Engine coolant flush (Zerex Super Radiator Cleaner, distilled water, Zerex Asian Red 50/50 mix.)
- Replace radiator hoses, PHH & thermostat
- Rebuild the Power Steering Pump and all lines
- Oil Pump gasket, and Dizzy O-ring
- Oil Change (Mobil 1 High Mileage Synthetic Oil w/ Toyota or Mobl 1 filter.)
- New belts
- Water Pump
- Fan Clutch
- Spark plugs, Distributor, and wires
- Fix the rust spots on the back window, and all wiper arms
- Remove and clean carpet, replace foam padding
- Respray the frame with rust inhibitor
- New belts
- Water Pump
- Fan Clutch
