scottryana said:I know I am kid of late to the game and haven't read the whole thread yet, but the top of that piston looks like it was running lean, hot or pinging. Did you get the numbers back from your injectors did you have one with a bad flow before they were fixed? I would definitely replace it while you are this far into the motor, I could see that piston cautostophically failing if leaving it the way that it is.
guy like me to do?Not a piston damage expert but IMHO the photos in post #85 almost look like the top of the piston melted then flowed over the edge a bit but was stopped by the cylinder wall??
Any updates?
dranven said:I talked to a Toyota tech and a few locals and all are convinced it was foreign object damage. I got mixed opinions on replace vs. leave it alone, but in the end it scared me enough to replace it, "since I'm there".
New piston was ordered, along with a ring set. Flex hone is on the way and should be here by early next week, then the updates will continue! So basically, I'll be replacing the piston and reringing all cylinders. Rod bearings will be case by case, but the Toyota Master Tech saw my no. 6 bearings and said he would not bother to replace them. Good enough for me.
Updates to come.
Sounds like my option D
Keep the faith brother... You're doing fine.
Get some plasti-gauge and assembly lube. What size rings did you buy? Check FSM for specs on ring gap. check gap at top, middle and bottom of stroke. cylinders do NOT wear evenly. Either research how to carefully manually file the rings or buy/borrow a ring filing tool.
You might also check out the tool for installing the rings on the pistons. Not necessary but remember rings are very brittle and will break easily if mistreated. YouTube I'm sure has something on these topics.
You'll also need a ring compressor. I prefer the corrugated type as they will not try to enter the cylinder with the piston.
Make sure to properly offset the ring gaps when you reinstall the pistons. Put rubber hose over the connecting rod cap bolts to help guide them over the crank and to keep them from damaging the bearings.
I would measure your rod bearing clearance with the plasti-gauge on at least on connecting rod. Check readings in FSM to help determine amount of wear.
When honing the cylinders use regular motor oil and be careful to protect crank and ensure no grit/oil from honing gets on crank/bearings.
While the bead hone is spinning do not let it extend out of the cylinder top or bottom.
You can YouTube or call me again if you like. I deploy in 13 days and will be unreachable for awhile![]()
OK so...a correction to my correction...I was right the first time.Whoopsjust discovered those are NOT fusible links. Thought I'd better double check and...they turn out to be just connectors. I wanted to post the correction, because I don't want to be posting mis-information. No wonder I never had any trouble with 'em.
Sounds like my option D![]()
Also, just a note on the piston wrist pin. After removing the retaining rings, the pin was knocked right out with a hammer and wooden dowel. The new piston came with a new wrist pin, which did not go in as easily at first. The FSM calls for heating the piston before installing. Instead, I stuck the wrist pin in the freezer for about 45 mins. It went in pretty easily after that.
More updates today or tomorrow.
Dranven, it's hard to tell from your pic but it looks like you need more motion on the hone. I'd maybe do the other 5 cylinders and come back to #6 for a touch up.
Subscribed. I have a 97 FZJ and may be doing this in the next year or two. I have no reference for power feel comparison but mine seems to be lacking in the umpf department.
This is good stuff.
Maybe I missed it in the thread, but what are you doing with the head? I know you sent it out, but what were the specifics of what was worked on?
