Damn, your rig is looking great! I can't wait till I can do some of that heavy metal stuff on mine.
Keep up the good work!
Mine does the same with a 2"ironman lift with 30mm spacers. I disconnected my front ds and it went away. Yet one more thing to add to the "list"..
Hmm. Is this the reason people install a part time kit? So they can be part time on the road and then full time on the trail?
I've noticed the "grrrr" sound on mine too. 2" Ironman lift, no spacers up front yet, caster correction done.
I'm thinking driveshaft U joints. Anyone concur?
1 week update: Truck drives great! No trouble whatsoever! I'm going to drain the oil and coolant in another couple hundred miles.
Moving right along. I took off the fan shroud, fan, fan clutch, belts, alternator and other related things. I went over to meet up with Tools R Us and Inkpot and give them my fan clutch. Tools R Us is going to give it a makeover.
After a big pain in the ass, I got the upper intake plenum off.
The first 5 bolts and 1 nut came off by me reaching from the top of the engine and a bit of patience. The 2nd nut and last bolt were quite a pain. It required this from under the engine:
Upper intake is going on today.
Here's the "old":
Here it is cleaned:
And here it is with all new vacuum lines:
Notice the custom EGR block off plate, as I will be deleting the EGR system using the resistor mod. The EGR hardpipe was also deleted from the head and a blockoff plate was installed there as well. Also, a freezeplug was put in the hole on the exhaust side. Thanks to ToolsRUs for the resistor and advice.
