- Thread starter
- #101
Home, sick today - figured that I'd post pics of current progress.
Stainless steel T-stat housing, I have way, way too much time into making it look like an off the shelf part. It clears everything by not very much.
The little gauge is a glycerin filled, 316 SS movement 60 psi industrial gauge destined to become a fuel pressure gauge. Plan is to mount it somewhere near the throttle cable housing anchor bracket.
I've also made the late 80's K5 transfer case shifter fit into the stock hole and mount like it was a stock part. I'll be using the original lower boot as just a gasket between the shifter base and the trans tunnel. Once I have the lever shaped to work the stock upper boot will work and look at least nearly stock. To make the GM lever fit under the dash I had to shorten it. So that meant that I had to alter the lever ratios so that everything ended up back in the same place and that the lever wasn't too hard to move.
Shifter base sans lever and shift lever gate:
Levers and op-rod just before test fitting the jam nuts. I need to grind the nearest strong-back on the t/c lever for nut clearance. I need some longer M8's and Nylox and to remove the excess lever length. Then all of the lower stuff can go in for good.
