78fj40mg
TLCA #23510
Quieter than a RR? RR meaning rail road of course?
That's not what I meant, however, you're on the right track.
I was't sure - Mile?
Railroad or Range Rover?
Either would be an improvement!!
That floor insulation is probably good idea for your climate...It would just take PITA to remove if you want to go back to stock...I am planning to wrap the exhaust under the driver floor with that fiberglas Kevlar wrap they are selling in Autozone for wrapping exhaust headers.It shoud lower the temperature some..I am surprised that your 78 gas tank opening got 90 degree sides but my 77 has 45 degree sloped sides.That would explain slightly bigger fuel amount in specs for 78..I also put the reflective aluminum membrane with felt on my floor and will see if there will not be a problem with the moisture..Time will show.I recently removed my gas tank too and it has 2 stripes of rubber tape glued on tank..for 3 years the space under the tank is in excellent shape..I have to tell that I like your thread and all the adventures you are doing in your 40...The pictures of the landscape around LV are fantastic..Specially if there is 40 in it...Good jobMike
That's a good point with rusting....I covered my exhaust with ceramic paint and wanted to wrap it from headers to about that step behind the back seats...I live in N part of TX,but it is still humid here so I might take it in consideration..Yeah basically NO public land in TX at all...maybe 1%...Everywhere I go is neither ranch gate or No tresp.sign...Even NC got a lot of public land...I was in LV last year(2014) passing through to Death valley an CA..Past Kingman,AZ towards LV There is a sweet ghostown Chloride with rock paintings...road there was horrible but it was worth it...I got pulled over after I left and lady Cop was nice.I was driving left and right so she thought i was drunk...LOng way to LV after that...You driving in this direction with your 40 sometimes?
Danny,good job..It will serve its purpose...I wonder why Toyota didn't do this lining at all(special order)-saving money?I guess..If I wouldn't have such a good looking fine sprayed liner in mine I would probably to the same thing...Putting that transmission hump back was PITA!!good luck with thatHow does it stick-pretty well?Are you thinking to also line inside of your doors?I just sprayed inside of mine with Noxudol 300..Pretty good stuff..They also make 700-spray for inside cavity-waxy stuff.Made in Sweeden.Also sprayed left ambulance doors inside ...But you don't need all that-LV weather is paradise(just not in the summer)
In Europe we use similar thing to insulate concrete slabs against moisture and maybe Radon..heat it with the gas burner and lay it down..here in US they only use 6 mil plastic-I loughed first time I seen it...It will be cheaper to buy a new tub instead of hiring somebody to remove it![]()
my goodness this thread goes fast. I miss a day and 15 pages appear. Did anything happen on the '40?![]()
Finished insulating the rest of the tub (except for the wheel wells, I doubt I will insulate them).
Can't do much more until my rear harness arrives and I get it hooked up.
Cleaned and treated and re-laid the rear mat
