Build My '78 FJ40 "44"
Hi Don.
No wonder that rat looks anemic. It's lost most of its entrails after being chewed by a cat!
I'll gladly give you the benefit of my extensive pest control experience... ;)
I've tried the most powerful electronic traps and I don't like them because the batteries are too expensive (being six or eight size D with quite limited lifespan). Furthermore, when a rat is zapped they lose their bladder contents and that stuffs pretty stinky and also corrosive to the traps electrical wires. Not only that, they have to be positioned in a sheltered enclosure otherwise the rain destroys them! (although this is not a problem to you using them indoors of course.)
Then I tried CO2-powered units that inflict a blow to the head when the rat knocks a hair-trigger mechanism while going for the bait. They were no good because the bait paste (sold with the trap) wasn't attractive enough to rats, snails and slugs decided they liked the bait instead, and the mechanism was poorly designed with a slow leak ensuring each Co2 cannister lost pressure well before the bait container ran empty. (And I feared young kids may find the trap, poke their fingers inside, and then further rumours would spread about "the crazy old man in the street"). I tried this type for months and never made a single kill!
So I'm now back to the basics.. That box is there simply to limit the kill to rats and mice only. And since a rat can get through any hole it can fit its head through (and if you don't believe me on this there is a U-tube video that proves it), that entrance can easily be made small enough to stop birds, cats paws, and childrens' fingers etc from getting "whacked".
In my photo the trap is lying on its side and the rats head is caught in a relatively cheap plastic traditional-style rat trap that was placed inside. (At the other end of the box is another mesh screen that sits in slots so it's easily removed for clearing and setting purposes.)
The bait I prefer at the moment is bread smeared in peanut butter and stuffed tightly into the bait-receptacle in the centre of the trigger-pad area.
But I'm always learning... With the larger trap I'm now experimenting with using an whole fresh egg for bait. I know this attracts ferrets and stoats but I'm a little unsure how good it is at attracting rats.. Time will tell. This trap is pushed right under some agapanthus plants to stop birds from going inside (because it has a larger entrance and can kill hedgehogs which are another introduced pest, although many gardeners like them because they eat snails and slugs).
Rats are very timid, cautious and intelligent. But they're also inquisitive and, if a trap is on their normal route and made attractive to them they will eventually summon the courage to explore it. The more they become familiar with its presence, the more they're likely to enter and trip the trigger mechanism.
Hope this helps..
:beer:
Texas rats and gophers always preferred peanut butter... Creamy not crunchy :cool:
I would think baiting with a whole egg might attract snakes... You do have snakes down there, right?
One of the really nice things about your threads is that they encourage such a wide range of topics for conversation Danny!
Our rats must be cuzzies to yours because they like the creamy version too.
No we don't have a single snake in New Zealand (unless you count the politicians who are in power. Hmmm.. Or are they rats?).
:beer:
:beer:
So, Oz got all the slithering snakes and We (you and I) got all the two-legged snakes... Peter may disagree on my two-legged observation...
44 has a warped wheel... One of the four with hubcap clips. I've swapped in the spare and removed the hubcaps.
Now, I will have to decide whether to buy another hubcap-ready steelie... Or, replace all five wheels.
I'm not a purist and would really like to use my Hi-Lift Lift-Mate to lift at each wheel... I can't do that with the OEM steelies...
I posted this in Tires and Wheels Tech and @Output Shaft suggested the 8 spoke US Wheels wagon wheels... He uses them on his 60.
This is the wheel I'm considering... But, I can't find them in 6 lug 15x5.5, with 3.50 bs... But these are 6x5.5 15x6, with 3.75 bs.
Does anyone see any reason these won't work on my '78, with front discs and back drums, running 30x9.50x15 tires?? http://www.summitracing.com/parts/usw-70-5660/overview/
those are old school wagon wheels... i used to have them on my rig.... MANY years ago :)
if you were going to chuck the bent rim.... maybe you can pull the clips off... they are useful
I like that look and I really would like to be able to lift from my wheels... there's no hurry, I can use the warped wheel as a spare while I make up my mind.
But, I'm a bit confused by the backspacing... some people say 3.50 is the most that will not rub... others says they run 3.75 and even 4.00 with no rubbing. I think that, with 30x9.50x15 tires, these 3.75 bs wagon wheels would be fine on 44... thoughts?
i have always had 3.5 bs
i have heard of other using different here and there but.... cant give you a definative on if these exact ones will work or not
might even want to think about going to 16" rims... the 15" are loosing options
Good thought Johnny, I hadn't considered that!! What I may do is find a place to straighten my wheel and drive them until I need new tires. Then go to 16"... Thanks!!
:beer:
Snakes, or rats. Doesn't matter. All politicians are vermin. So, it does sound like you do have vermin there, the two legged variety.
I have very successfully used nuts, and other hard food type items, stuffed very tightly into the metal type bait holders for mice. Doing it this way ensures that the vermin have to work to get the bait, and then the bait gets them. I've also successfully used both crunchy and creamy peanut butter for mice. But, rats have been a different story. I will have to try using their inquisitive nature against them with some kind of box similar to what you did Tom.
Don
Well, I don't know where I left off, before the "rat the size of a holstein calf" (ala Stephen King in Night Shift)...
I've been working on 44, in dribs and drabs, as I feel up to it, and here are the "spicks and specks" (ala Barry Gibb 1966) of what little I've accomplished thus far.
Carbon Fiber on my overhead cabinet... for anyone as old as me, its like installing contact paper... still need to reinstall the lock and "paint" the raw wood that shows thru the cracks... considering putting this stuff on as a headliner... but that will be for my daughter and her boy friend to do... he's 6'7"... I like to see him crawling around in there... makes my old 5'6" frame feel somewhat better...
Insulation on the floor... I have one more small spot to do, but need to get my new rear harness installed first... it includes the seat belt wire and the fuel sender wire and a new grommet. I will need to cut holes for the shifters and bolts and stuff...
This is what I did with the main tank "nest"... anyone see a problem with this?
It looks great Danny! Your rig will be as quite as a RR. Are you insulating the firewall as well?
I'm insulating the firewall as best I can without totally disassembling everything.
It's not quiet for which I search, it's summertime heat from which I flee...
Quiet will be the residual affect, kill two bird with one stone. I know that the driver's side is the hottest seat in the house, insulation is a good measure and remedy from the +250* F exhaust heat radiating underneath your feet.
