Mr. Wayne (9 Viewers)
Looks great. The only option to keep this height is disconnecting AHS power while it’s in high I believe
It drives relatively poorly when it’s this high, partly because of the camber change with being so high, there’s not much down-travel left in the suspension and the damping is pretty stiff with the higher AHC pressure needed to keep they height. I bet there’s other ways to address these issues with changes like adding coil spring spacers and adjusting the alignment.
Yup. It's eye opening how much worse traction and putting down power is when the suspension is lifted aggressively. Yes alignment, but it's also the geometries and down angles of the suspension links. Mild lifts that keep the geometries in its sweet spot are the best kind of lift.
AHC Long Travel is the enabling mods to put AHC on steroids.
That's not really an effective strategy. Best to work with the system rather than against it.
Mr. Wayne got CarPlay for Christmas.
