Mpg while towing. (1 Viewer)
Just seeing if this mpg seems normal. I towed my 19 ft center console boat up to maine from nj. Approx tow weight 3500 lb.
I kept the speed around 65 to 70mph. Tank average was10.9 mpg. No traffic jams but plenty of long uphill sections. I have 10 k miles on my replacement engine (replacement engine had 45k on it). Synthetic fluids in diffs and engine. Rest of truck has 245k on it. I towed both in 5th gear and in 6th with power button turned on. Premium gas. 35 psi cold in tires. Outside temp 80 degrees.
I kept the speed around 65 to 70mph. Tank average was10.9 mpg. No traffic jams but plenty of long uphill sections. I have 10 k miles on my replacement engine (engine had 45k on it). Synthetic fluids in diffs and engine. Rest of truck has 245k on it. I towed both in 5th gear and in 6th with power button turned on. Premium gas. 35 psi cold in tires. Outside temp 80 degrees.
Hell...I'm jealous. I average around 9 when towing our 4kish travel trailer. 33s, OTT tune with ECT button on, transmission in S6 in a '16 LC. I averaged 8.3 during our 4,400-mile trip this summer with limited dirt with the trailer. That also included some non-towing trail time...and a LOT of climbing. But it hurt. :blackeye:
Seattle to Denver pulling a 4x8' enclosed U-Haul = 10-12 mpg. with maybe 500# of contents.
8-10.5 MPG towing 5800lbs; 6-8MPG in the mountains on rt 70 west of Denver.😖
7-9 mpg at 65-75mph.
Towing an 8k Airstream and RTT, with combined weight or 15.5k. On 35 A/T or 37 R/T tires.
8-9 mpg towing my campers going 55-65mph. Both are ~7k lbs. the black series gets closer to 9mpg but it is shorter, narrower, and the front slopes more then my outdoor RV.
From my experience this is extremely unusual, something must be VERY wrong because I have never averaged more than 9.5, it’s usually less.
Pulling my built 80 series on a uhaul trailer with some mountains to go through I get 11-12 on premium gas. It's a stock 14 lx570 with the factory 20" rims and tires. Usually tow around 65 so it will lower an inch or so and be a little more slick through the air. I'm not sure how it does this but it just does. I do know it gets worse mileage when the cruise control is on. So it's always off. I do coast down hills and speed up before hitting another one.
We tow a Lance 1995, about 5700 pounds, in the mountains mostly. Get between 6-10 mpg according to computer, about 150ish miles a tank if lucky. Works out good because I need to walk around and stretch
