- Thread starter
- #21
pic 1 - finished rotor / hub assembly
pic 2 - assemble the cleaned birfs and inner axles. I did not use the tack method but used the stock clip. I read up on this and many have used several devices in order to hold the clip against the axle in order to slip it in while compressed. 5 minutes with an extra set of hands from the wifey and no prob, they were in. You really need an extra set of hands here. I basically held the clip in with 2 flathead screwdrivers while she pounded on the top of the axle. The whole assembly was in a vice at the time.
pic 3 - clearance the housing to accept the larger mini birfs. I was surprised at how much griding I had to do. I took more off of the bottom than the top. I took the birf and test fit it to see where it was hitting and then marked it with a sharpie. One note here, I found that I only test fit the birf without it being attached to the inner axle, this turned out to be a mistake. After clearancing it, the birf would slip in fine. Later, when I went to put in the whole axle / birf combo I found it did not just slip in. I am guessing this is because the inner axle orients the birf up some so the entry point into the housing is different than if I were doing it with just the birf. So lesson here is to test fit with the birf and axle connected, probably with the seal in place. I was lucky and was able to tap in the birf to get it inside the housing.
