splitshot
Head cook, Bottle washer, and Peace keeper.
Trade off for an electrical job I'm doing. No bottle or regulator.
Couple of questions: Drive wheels are stamped .035 on the outside face, but the inside grove is the one that drives the wire...Both groves the same?
Also, looks like it has been set up for a 40~lb spool, I sold all my smaller stuff, will a 12lb spool fit this hub?
'Spose I need to do a search for a user manual...
Thanks for the link and .02..
Lol, Charles, your like the D' Animal of the welding world..
Found it locally (suppliers appreciate it when you call with the part #).
Any special distance from the drive rolls when I reverse the inlet guide?
I'm not as ugly as D' Animal and only have 10% of his fur. I have only 2 Stihl chain saws. I think Dan have around 150.![]()
Ok, but how many welders do you have, lol.
I'm happy. First run on some scrap, need to fine tune my speed along with the settings. Pile on if you have any constructive criticism.
Also, all I get from the manual is to run 25 cfh on the gas, sound right? (seems like I lost a bunch doing this).
I'm down to 8 welders now.
Try cleaning the scrap before welding. Grind off the rust and mill scale and you'll get much cleaner welds.
25CFH shielding gas is not needed. More is not better and can cause problems as it creates too much turbulence and starts to suck in air. Try turning down the flow rate until the weld quality suffers. At this point, increase the flow to the point where you have proper shielding. Many people get away with just 15-20 CFH if welding indoors.
The weld looks good, but it is a little high in the middle and the toes needs to filled in. The "toe" of the weld is edge of the weld. In the picture, the toes would be the top and bottom of the weld bead (looking horizontal). Try more voltage and/or move across the center quicker and spend more time on the toes to let it fill in.
What size metal and what welder settings are you using? Are you left handed?
If right handed, try pushing the weld by starting on the right and moving right to left. You moved left to right and were pulling the weld. Pulling will cause a taller bead profile, but result in more penetration.
Well I cant wait to get working with it, with some of the side jobs lined up I should be able to pay for the out of pocket money invested. Did I say I was happy?(Estatic comes to mind).
Maybe my round tubing welds will even turn out better, always have been a pita to look good. May pick your brain again, Thanks.
