, I like to attach more directly to the chassis
James
I totally agree with the "no lift" people. If you want bigger tires, cut the sheet metal. And then cut some more.
It is not even hard to fit 37" to 70-series. Stableness (is that a word?) is something else than in SOA trucks and clearance is still the same under the axles. I have 37´s and no lift on my 73. Just cutting and flipped front springs.
hello, nice ride, but you need to upgrade some very important things..
1. stop raising the body!! lower it again and cut -much- more of the body to fit the tires. you gain lower Center of gravity. Then buy fiberglass mud guards.
2. throw out the blade-suspension for linked suspension and springs. you will have hell of a lot better and softer suspension.
3. -MUCH- wider rims for the tires!! for a 38" Gumbo Monster Mudder I would go for 12" to 14" wide. you gain loads of extra float on mud and sand, specially if you deflate the air pressure in such circumstances, down to 5-7 psi. (as I do in snow at home, sometimes to 1.5 psi).
here are some links of my ride as I am modding it for 38" tires, longer wheel base and 60 cruiser axles and motor. (this one from a glacier
and then some from others:
http://www.f4x4.is/new/files/photoalbums/129/14433.jpg
forrunner with real mud guards... 44" tires:
That works ok in theory, but not always that great in practice, well in my case anyway. If you have a car that flexes better than a brick you will have scrubbing issues. With stock guards and 31'' stock tyres on stock rims I had rubbing issues, on the top of the front guards. I've chopped and chopped, not much left and now my 33''s rub abit and my 35''s abit harder on compression. In my situation a 2'' body lift would JUST clear my 2'' chopped guards, thats 4'' of guard lift to clear a 35''. No chance of fitting 37'' with flexy suspension and no body lift.
I limited compression 3 cm (a bit over one inch), flipped front springs and 37" boggers don´t rub. 16" wheels. It is not a RTI champion, but i like stable more than monster flex. Lockers are there to help to keep the traction.
I would like to see a closeup photo of the rod holders. That is a great idea! Awesome rig!
i posted a pic of a mates troopy in the pics of mded 7x series when he lets his 35's on 8" wide rims down for the beach ,drops the straight to 8 psi and has never pulled a tyres of the rim
