Build Mid Life Adventure 2010 LX570
Question, How big a tire can I run without doing fender mods? Wheel spacers are fine.
As big as you want! Fender mods not necessary with the right offsets. Details for 35x12.5 in sig in you're interested.
You can go even taller trading some width for more height. Check out @grinchy 's build with a 275/80R18
BTW, fine looking rig you got there!
I just recently went to a 295
Easy-peasy
Which big are you after? Tall? fat? or both?
Not really sure just starting to think. I just want biggest and widest w/o mods.
@tbisaacs has a good fit with the 295/70r18. Pretty wide, pretty tall, common size with lots of choices.
getting into the 35x12.5” wide a body mount chop is probably necessary.
the 35 I run is narrow, so no bmc required but it is an odd size so not much choice of tread.
If you go to 17” there are a couple 34 and 35x11 options that will fit without a bmc.
Kinda don't want to buy new Wheels. Maybe doing what @tbisaacs has would be best.
So, I spent Monday installing the Dissent rear bumper. Unfortunately the current walk through, by @radman which is amazing and thorough, has a step that is not necessary for the current version of the Dissent rear bumper and cost me 2-3 hours. Half of the waste was due to the mfg of the tap and bit set I bought packaging the wrong tap in the sealed package and me having to drive to swap to the correct tap. Long Story Long, If you buy a current rear bumper you DO NOT need to drill and tap the holes in the rear bumper on each side of the receiver. There is not a mount point there on the current version of the Dissent rear bumper.
My other hiccup was when installing the swing arm mounting points. I used the third hole on the outside used to align the internal nut plates to the external holes in the bumper wings. I had bolts in all 4 holes thinking this would align the holes properly. But they did not. I would say center the nut plates or even justify them to the top. The justifying to the top may change on Monday when I hopefully finish the install. And install the front and get some wiring done.
Thanks to radman for all of his work!
Dang. You mean the swingarm hinge mount didn't align with the captive nut plates when you used the 3rd hole to align? I remember having to expand the hinge holes (with a die grinder) a little so the bolts would align. If you justify too high, your swingarm might not sit properly on the striker plate.
How did you feel about swapping in the new AHC mount?
No, both Pass and Drivr side inside holes are too low and bolts will not even start. I figure 30-45 min each side and I can sort it out. I will post and reach out if I have questions. I will def pay attention to strike plates. Hope I can get it in one more try and don't need to do it a third or fourth time. What kinda clearance do you have on the strike plates? Pics?
As far as the AHC mount........F*#K that third nut on the back. I got it loose enough with a wrench them uses a flat head to turn it till it would pass the stock mount. Then I was really happy I am an octopus and used my 8 arms to easily swap them out and finish the install on the new mount.
The third hole is with in a hair of spot on.
Set the arm down in the closed position. The plastic VHD (very high density something..) should sit flat on the striker plate, and the hinge side should sit in the hex hole opening. At that point, everything should be pretty much aligned to bolt on.
Take a straight on pic to show that alignment?
Yeah, a straight on pic. I think that might help.
@radman
Hey I think you said in your thread that you wired to the stock fog light harness. Did this work there are some bits in the harness that came with my lights and I don't know if i need them or not.
Or maybe @1world1love knows.
@radman
Since you are wiring into the existing fog harness, you won't need much of the additional hardware. I assume that there is a relay (what you are holding) and a switch, but you really only need to splice in directly to the existing harness. I wish I could offer more guidance there but Ben wired that up. I do think that there are many threads on here about how exactly to do it (ie where best to splice in, etc).
Looks like @kcjaz did this as well.
He ran into something that you are also likely to run into, which is that the draw of the new fogs will exceed the draw of the OEM lights. In that case, you will need to keep the relay and wire that in to an appropriate fused source. Then you can splice the switched power into the existing harness.
I cant find where someone said which wire is pos and neg.
They are rigid. I mean the OEM. Green and white.
