Maximum Size Tire For a Stock FJ75 P/U? (5 Viewers)
javelinadave
GOLD Star
Scottsdale
Just like the title says, what is the largest size/tallest tires that I can fit on one piece (non split) rim 16" factory steel wheels without having any rubbing? I searched both here and online and the range I am seeing is pretty significant.
Thank you!
Dave
Hello,
You can fit 33 in. x 10.5 in. tires with no rub. Anything taller or wider will rub; it may also wear your axle seals/bearings faster.
35 in. tires require a front axle modification.
The search function is your friend.
Juan
I thought there were a couple of 75 series pickups in the MUD classifieds with 35x10.50r17 wheels on them.
This would prove the 35" tires work
From there, your choices are:
Squeeze a 315/75r16 on a 6" rim - will work but you (and I) will be hated
OR jump to a wider aftermarket wheel with your choice of 16" wheels (0 offset) from these suppliers below
Things will be VERY tight, but I think I am correct. Please research, it is your money not mine
Bradley wheels -Japan
Volks- Japan
SCS Wheels
Method- I am pretty sure
Fifteen52
Nomad
Lots of great brands out there- most are aluminum. You would want 16x7 or 16x8
Another excellent choice is the 80 series steelies wheel in 16x7. Will need a spacer but looks great.
35" tyres will rub, I used to have them on my FJ75 with a 2" body lift and they still caught on the back of the front guards, I always found 33" tyres to clear ok, I'm running 33" now but still with the 2" bodylift
I think the 255/85R16 size is only used for mud terrains. Not many all-terrain options.
Cooper Discoverer ST Maxx come in that size. They are a bit aggressive but more of a Dura-trac copycat than a mud terrain. Supposed to be for all situations.
@saltycoconuts just sold his 75 series with 35x11.50 tires. Looked great.
Actually 35x10.50’s!
Such a great fit for 75’s
Although whenever I get my next 70, I think I’ll stick with a 255/85/16. A lot more availability in a pinch.
If I decide to switch, I will probably revert to 15" wheels.
Then I can buy tires AT's measured in inches not confusing SI Metric math code.
With all due respect, I think that would be a major step backwards. Way more options with 16" rims. It's not that difficult to look up the dimensions in inches of any tire. Here's a handy chart for you with everything metric converted to inches. It also lists all the tires that are sold in inch dimensions.
if I remember correctly the AT4W is supposed to come in the 255/85/16
can confirm. just purchased for my 1998 FZJ75 PU. basically it's those or MT's.
  • Back
