I am still waiting to get the body and chassis back from RVA Hot Rods and Restorations...In the meantime I have been collecting parts.
Like most builds this one is starting to take a different direction. I have been thinking about really wanting to keep a manual trans. I also really wanted overdrive. I ran across a deal on a NV4500-split case combo that bolts up to a SBC. OK I bought the combo. Now I have a pass drop t-case. No worries I have pass drop D60 fronts. Now the rear diff output if offset as well. Could always narrow a 14B housing and offset the pinion. Or put my nice 78 FJ40 axles back in it and save a lot of trouble.
This brings up the SBC that was in it. I have looked at A/C set ups and compressor mounts and relocation kits, it looks like the SBC set up is much better and easier than the LS option. AND the NV4500 will bolt right up and the SBC will bolt right back where it was as will all the plumbing and cooling and electrical. See where I am going with all this?
This all brings up the ride height. I have owned and driven a spring over FJ40 on 35's. This one appears taller or I am getting older! I know the current springs on it are 2.5" lift springs so it sits up even taller. This brings up mutliple options:
1. Go back to the 4" lift and Cruiser axles that were in it before
2. Keep the spring over and use stock lift springs with cruiser axles
3. Keep the spring over and use stock lift springs with a pass drop D60 and 14 Bolt
4. Go back to the 4" lift springs and do a SUA with pass drop D60 and 14 Bolt
Here is a pic of my 77 with the 4" lift and cruiser axles. 33" tires
I am thinking of putting the 2.5" springs on the 77, tall skinnys, and I found a nice 2F to replace the current SBC, and and make it more stock. I have been looking at some of the FJ Company builds and they do a 2.5 OME lift and skinnys.
Of course my wheels are spinning thinking of this 74 stretch project and my 77.
The green one is the 75 I drove everyday out of college. 33" tires and about 3" lift. I really like the way it sat and was easy to get in and out.
